Ana içeriğe geç
HP Split 13-r010dx Hard Drive Replacement
Neye ihtiyacın var
  1. HP Split 13-r010dx Hard Drive Replacement, Front and Back Panel: adım 1, 2 resimden 1. HP Split 13-r010dx Hard Drive Replacement, Front and Back Panel: adım 1, 2 resimden 2.
    • Locate the four screws at the bottom of the device. (Note that the keyboard attachment is missing from this device.)
    • Use a Philips head #0 screwdriver to remove each of the screws (Size: 4mm)
  2. HP Split 13-r010dx Hard Drive Replacement: adım 2, 2 resimden 1. HP Split 13-r010dx Hard Drive Replacement: adım 2, 2 resimden 2.
    • Gently wedge the plastic opening tool in between where the display and back panel meet.
    • Slowly and gently apply force to the plastic opening tool in a downwards motion to loosen the front panel from the back panel.
    • Rotate the device so that the side is facing up and repeat the previous step for the sides.
    • Do NOT attempt to wedge the plastic opening tool on the bottom . Once the sides and top are loose you are ready to continue to the next step.
  3. HP Split 13-r010dx Hard Drive Replacement: adım 3, 1 resimden 1.
    • Gently and slowly pull the front and back panel away from each other (in opposite directions). ( Pulling them apart will not separate the two panels)
    • Only separate the panels by a few inches from each other so that there is room to separate the front and back panel in the next step. Proceed to the next step.
  4. HP Split 13-r010dx Hard Drive Replacement: adım 4, 1 resimden 1.
    • Hold the back panel firmly and pull the front panel upwards to completely separate the front panel from the back panel.
    • The device is now ready to be repaired or replacements installed.
  5. HP Split 13-r010dx Hard Drive Replacement, Hard Drive: adım 5, 1 resimden 1.
    • Locate the hard drive. (The hard drive is located in the center of the device)
  6. HP Split 13-r010dx Hard Drive Replacement: adım 6, 3 resimden 1. HP Split 13-r010dx Hard Drive Replacement: adım 6, 3 resimden 2. HP Split 13-r010dx Hard Drive Replacement: adım 6, 3 resimden 3.
    • Locate the black strip of thermal resistant tape that is covering the upper right portion of the hard drive.
    • Gently lift up with the tape.
    • Fold the tape back away from the hard drive.
  7. HP Split 13-r010dx Hard Drive Replacement: adım 7, 2 resimden 1. HP Split 13-r010dx Hard Drive Replacement: adım 7, 2 resimden 2.
    • Locate the four screws (Size: 4mm) at each of the four corners of the hard drive.
    • Remove the four screws using a #0 Phillips head screwdriver.
  8. HP Split 13-r010dx Hard Drive Replacement: adım 8, 2 resimden 1. HP Split 13-r010dx Hard Drive Replacement: adım 8, 2 resimden 2.
    • Locate the lift tab. (The lift tab is located at the bottom left corner of the hard drive).
    • Gently lift up on the lift tab
    • Be cautious when lifting the hard drive from its designated slot, the hard drive is still connected to the device
  9. HP Split 13-r010dx Hard Drive Replacement: adım 9, 3 resimden 1. HP Split 13-r010dx Hard Drive Replacement: adım 9, 3 resimden 2. HP Split 13-r010dx Hard Drive Replacement: adım 9, 3 resimden 3.
    • Locate the connection of the hard drive to the device.
    • Gently grasp the connector cord and pull horizontally to the right. (Very little force is needed to disconnect the cord).
  10. HP Split 13-r010dx Hard Drive Replacement: adım 10, 2 resimden 1. HP Split 13-r010dx Hard Drive Replacement: adım 10, 2 resimden 2.
    • The hard drive is no longer connected to the device. Lift the hard drive up vertically and set aside.
    • The hard drive removal is completed.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Kim
201 İtibar
2 adet Kılavuz yazıldı
Bir Yorum
Is it possible to change the Wd5000m21k disk for a Wd5000m22k?
Pablo Cesar Zacarias - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 18
Her zaman: 4,522
