Ana içeriğe geç
HP Split x2 13-g210dx Back Panel Replacement
Neye ihtiyacın var
  1. HP Split x2 13-g210dx Back Panel Replacement, Back Panel: adım 1, 1 resimden 1.
    • Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
    • Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
    • Remove the four 4-mm Phillips #0 screws.
    • Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
    • You will hear popping noises as the clips separate from each other.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
How do I put the felt cover back on?
Prince Phoenix - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 406
