Ana içeriğe geç
HP Split x2 13-g210dx SD Port Replacement
Neye ihtiyacın var
  1. HP Split x2 13-g210dx SD Port Replacement, Back Panel: adım 1, 1 resimden 1.
    • Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
    • Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
    • Remove the four 4-mm Phillips #0 screws.
    • Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
    • You will hear popping noises as the clips separate from each other.
  2. HP Split x2 13-g210dx SD Port Replacement, Battery: adım 2, 1 resimden 1.
    • Remove the three 6-mm Phillips #0 screws.
  3. HP Split x2 13-g210dx SD Port Replacement: adım 3, 2 resimden 1. HP Split x2 13-g210dx SD Port Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the white connector clip from the connector port using a sturdy tweezers.
  4. HP Split x2 13-g210dx SD Port Replacement: adım 4, 2 resimden 1. HP Split x2 13-g210dx SD Port Replacement: adım 4, 2 resimden 2.
    • Lift the battery away from the device.
  5. HP Split x2 13-g210dx SD Port Replacement, SD Port: adım 5, 1 resimden 1.
    • Remove the two 4-mm Phillips #0 screws.
  6. HP Split x2 13-g210dx SD Port Replacement: adım 6, 2 resimden 1. HP Split x2 13-g210dx SD Port Replacement: adım 6, 2 resimden 2.
    Satın Al
    • Remove the yellow ribbon labeled "SD" in the left corner of the SD port board using tweezers or a sturdy plastic opening tool.
  7. HP Split x2 13-g210dx SD Port Replacement: adım 7, 1 resimden 1.
    • Lift the SD port away from the device.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 232
