Ana içeriğe geç
HP Split x2 13-g210dx Speakers Replacement
Neye ihtiyacın var
  1. HP Split x2 13-g210dx Speakers Replacement, Back Panel: adım 1, 1 resimden 1.
    • Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
    • Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
    • Remove the four 4-mm Phillips #0 screws.
    • Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
    • You will hear popping noises as the clips separate from each other.
  2. HP Split x2 13-g210dx Speakers Replacement, Battery: adım 2, 1 resimden 1.
    • Remove the three 6-mm Phillips #0 screws.
  3. HP Split x2 13-g210dx Speakers Replacement: adım 3, 2 resimden 1. HP Split x2 13-g210dx Speakers Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the white connector clip from the connector port using a sturdy tweezers.
  4. HP Split x2 13-g210dx Speakers Replacement: adım 4, 2 resimden 1. HP Split x2 13-g210dx Speakers Replacement: adım 4, 2 resimden 2.
    • Lift the battery away from the device.
  5. HP Split x2 13-g210dx Speakers Replacement, Docking Port: adım 5, 1 resimden 1.
    • Remove the two 4-mm Phillips #0 screws.
  6. HP Split x2 13-g210dx Speakers Replacement: adım 6, 2 resimden 1. HP Split x2 13-g210dx Speakers Replacement: adım 6, 2 resimden 2.
    Satın Al
    • Remove the clips from the docking port board with a sturdy pair of tweezers.
  7. HP Split x2 13-g210dx Speakers Replacement: adım 7, 2 resimden 1. HP Split x2 13-g210dx Speakers Replacement: adım 7, 2 resimden 2.
    • Remove the two ribbons labeled "Dock" at the top of the docking port board using tweezers or a sturdy plastic opening tool.
  8. HP Split x2 13-g210dx Speakers Replacement: adım 8, 1 resimden 1.
    • Lift the docking port away from the device.
  9. HP Split x2 13-g210dx Speakers Replacement, SD Port: adım 9, 1 resimden 1.
  10. HP Split x2 13-g210dx Speakers Replacement: adım 10, 2 resimden 1. HP Split x2 13-g210dx Speakers Replacement: adım 10, 2 resimden 2.
    Satın Al
    • Remove the yellow ribbon labeled "SD" in the left corner of the SD port board using tweezers or a sturdy plastic opening tool.
  11. HP Split x2 13-g210dx Speakers Replacement: adım 11, 1 resimden 1.
    • Lift the SD port away from the device.
  12. HP Split x2 13-g210dx Speakers Replacement, Audio Port: adım 12, 1 resimden 1.
  13. HP Split x2 13-g210dx Speakers Replacement: adım 13, 3 resimden 1. HP Split x2 13-g210dx Speakers Replacement: adım 13, 3 resimden 2. HP Split x2 13-g210dx Speakers Replacement: adım 13, 3 resimden 3.
    Satın Al
    • Remove the two purple ribbons labeled "Audio" at the top of the audio port board using tweezers or a sturdy plastic opening tool.
  14. HP Split x2 13-g210dx Speakers Replacement: adım 14, 2 resimden 1. HP Split x2 13-g210dx Speakers Replacement: adım 14, 2 resimden 2.
    • Remove the white clip at the top right corner of the audio port board using tweezers.
  15. HP Split x2 13-g210dx Speakers Replacement: adım 15, 1 resimden 1.
    • Lift the Audio port away from the device.
  16. HP Split x2 13-g210dx Speakers Replacement, Speakers: adım 16, 2 resimden 1. HP Split x2 13-g210dx Speakers Replacement, Speakers: adım 16, 2 resimden 2.
    • Remove the 4-mm Phillips #0 screw.
    • Lift the left speaker away from the device.
  17. HP Split x2 13-g210dx Speakers Replacement: adım 17, 2 resimden 1. HP Split x2 13-g210dx Speakers Replacement: adım 17, 2 resimden 2.
    • Remove the 4-mm Phillips #0 screw from the same location as found on the left speaker.
    • Lift the right speaker away from the device.
  18. HP Split x2 13-g210dx Speakers Replacement: adım 18, 3 resimden 1. HP Split x2 13-g210dx Speakers Replacement: adım 18, 3 resimden 2. HP Split x2 13-g210dx Speakers Replacement: adım 18, 3 resimden 3.
    • Carefully remove the bonded white and black speaker wires running along the bottom of the control board from the fastening clips.
    • Lift the speaker assembly away from the device.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 291
