Ana içeriğe geç
HP Split x2 Battery Replacement
Neye ihtiyacın var
  1. HP Split x2 Battery Replacement, Rear Cover: adım 1, 1 resimden 1.
    • Opening the device voids the manufacturer warranty.
    • Power down the HP Split x2 before beginning the repair
    • Separate the tablet from the keyboard by pushing the slider to the left and lifting the tablet from the keyboard.
  2. HP Split x2 Battery Replacement: adım 2, 3 resimden 1. HP Split x2 Battery Replacement: adım 2, 3 resimden 2. HP Split x2 Battery Replacement: adım 2, 3 resimden 3.
    • Remove the four white caps on the bottom edge of the tablet.
    • Use a tweezer to grasp white caps.
    • The white caps are easily lost. Store them in a secure place.
  3. HP Split x2 Battery Replacement: adım 3, 1 resimden 1.
    • Use a Phillips #000 screwdriver to remove the four 3mm screws.
  4. HP Split x2 Battery Replacement: adım 4, 2 resimden 1. HP Split x2 Battery Replacement: adım 4, 2 resimden 2.
    • Use a plastic opening tool to pry the tabs on the top, left and right sides of the tablet.
    • Only the top and sides have tabs. Remove all tabs before lifting screen.
  5. HP Split x2 Battery Replacement: adım 5, 2 resimden 1. HP Split x2 Battery Replacement: adım 5, 2 resimden 2.
    • Separate the cover and the screen.
    • Gently lift the screen out of the cover.
  6. HP Split x2 Battery Replacement, Battery: adım 6, 3 resimden 1. HP Split x2 Battery Replacement, Battery: adım 6, 3 resimden 2. HP Split x2 Battery Replacement, Battery: adım 6, 3 resimden 3.
    • Remove black stickers
  7. HP Split x2 Battery Replacement: adım 7, 3 resimden 1. HP Split x2 Battery Replacement: adım 7, 3 resimden 2. HP Split x2 Battery Replacement: adım 7, 3 resimden 3.
    • Pull on the blue ribbon to disconnect the cable
    • Disconnect both ends of the cable
  8. HP Split x2 Battery Replacement: adım 8, 3 resimden 1. HP Split x2 Battery Replacement: adım 8, 3 resimden 2. HP Split x2 Battery Replacement: adım 8, 3 resimden 3.
    • Flip up the retaining flap with either a spudger or your fingertips.
    • Disconnect the ribbon cable by gently pulling on it.
    • Disconnect the sliding connector with the pointed tip of the spudger and gently remove the cable.
  9. HP Split x2 Battery Replacement: adım 9, 3 resimden 1. HP Split x2 Battery Replacement: adım 9, 3 resimden 2. HP Split x2 Battery Replacement: adım 9, 3 resimden 3.
    • Remove all eight 3mm Phillips screws using a J1 screw head.
  10. HP Split x2 Battery Replacement: adım 10, 2 resimden 1. HP Split x2 Battery Replacement: adım 10, 2 resimden 2.
    • Gently lift up the battery as a whole
    • Make sure the battery is free to move on both ends.
    • Battery has two cells connected by a bridge making it a unit.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Alvaro Esperanca
239 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S6-G6, Wilson Spring 2017 IUPUI, Team S6-G6, Wilson Spring 2017 üyesi
IUPUI-WILSON-S17S6G6
4 Üyeler
2 adet Kılavuz yazıldı
5Kılavuz Yorumları
Does the HP split have 2 batteries? One in screen part & 1 in keyboard part?
Genny Gallup - Yanıt
can you email the battery part number and where I can buy in the US ?
my email is leprince1@gmail.com
Imran Karram - Yanıt
I have a hp split just like this one i actually preessed down hard on the power bottom because it wouldnt turn on so the power bottom is pushed in so i really can’t power it up .. But before that my computer would not charge sometimes
can you please try an point me to the right direction on this issue
please email me at
galvanmichelle7@gmail.com
Michelle Marie - Yanıt
I own a split x2, but my screen is broken and my keyboard stopped working… is there a way this can be fixed??
Dosunmu Adelani - Yanıt
The screen is working, however the keyboard portion is not powering up . The light is not coming on when the power supply is placed in it and the bottom of the keyboard gets very hot once plugged in. Help needed.
LENNY - UNA PHILERT - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 28
Her zaman: 13,138
