Ana içeriğe geç
HP Split x2 Rear Cover Replacement
Neye ihtiyacın var
  1. HP Split x2 Rear Cover Replacement, Rear Cover: adım 1, 1 resimden 1.
    • Opening the device voids the manufacturer warranty.
    • Power down the HP Split x2 before beginning the repair
    • Separate the tablet from the keyboard by pushing the slider to the left and lifting the tablet from the keyboard.
  2. HP Split x2 Rear Cover Replacement: adım 2, 3 resimden 1. HP Split x2 Rear Cover Replacement: adım 2, 3 resimden 2. HP Split x2 Rear Cover Replacement: adım 2, 3 resimden 3.
    • Remove the four white caps on the bottom edge of the tablet.
    • Use a tweezer to grasp white caps.
    • The white caps are easily lost. Store them in a secure place.
  3. HP Split x2 Rear Cover Replacement: adım 3, 1 resimden 1.
    • Use a Phillips #000 screwdriver to remove the four 3mm screws.
  4. HP Split x2 Rear Cover Replacement: adım 4, 2 resimden 1. HP Split x2 Rear Cover Replacement: adım 4, 2 resimden 2.
    • Use a plastic opening tool to pry the tabs on the top, left and right sides of the tablet.
    • Only the top and sides have tabs. Remove all tabs before lifting screen.
  5. HP Split x2 Rear Cover Replacement: adım 5, 2 resimden 1. HP Split x2 Rear Cover Replacement: adım 5, 2 resimden 2.
    • Separate the cover and the screen.
    • Gently lift the screen out of the cover.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Ricky Huitema
464 İtibar
2 adet Kılavuz yazıldı
Ekip
Texas Tech, Team 22-5, Rauch Fall 2015 Texas Tech, Team 22-5, Rauch Fall 2015 üyesi
TTU-RAUCH-F15S22G5
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 21
Her zaman: 4,182
