Giriş
Did you accidentally drop your device and shatter the screen? This guide will instruct you how to replace your broken screen. The first five steps tell you how to remove the rear cover of the case. The remaining six steps explain how to replace the screen.
Neye ihtiyacın var
Separate the tablet from the keyboard by pushing the slider to the left and lifting the tablet from the keyboard.
Apply pressure to to the sides of the tablet.
Separate the digitizer from the the body of the tablet.
Glue was not very weak for me. I broke my screen trying to remove the digitizer. Recommend using a heat gun to weaken glue that is used to hold digitizer in place.
11 farklı kişi bu kılavuzu tamamladı.
5 Yorum
This is not helpful because the one I am working on has no screws.
I also have a Split x2 with no screws
I want change my screen because My screen is broken but I do not know , where I can buy my screen
ebay or amazon
Is HP Touch Screen Digitizer Glass for HP Split X2 The same as the screen being replaced here?? I need to know
