Ana içeriğe geç
HP Sprocket 2-in-1 Camera Lens Assembly Replacement
Neye ihtiyacın var
  1. HP Sprocket 2-in-1 Camera Lens Assembly Replacement, Outer Casing: adım 1, 2 resimden 1. HP Sprocket 2-in-1 Camera Lens Assembly Replacement, Outer Casing: adım 1, 2 resimden 2.
    • Remove the back cover and any printer paper inside the device.
  2. HP Sprocket 2-in-1 Camera Lens Assembly Replacement: adım 2, 2 resimden 1. HP Sprocket 2-in-1 Camera Lens Assembly Replacement: adım 2, 2 resimden 2.
    • Using the Jimmy, slowly pry open the outer edge of the remaining white plastic on the back.
    • Remove the plastic from the device once it lifts out freely.
  3. HP Sprocket 2-in-1 Camera Lens Assembly Replacement: adım 3, 3 resimden 1. HP Sprocket 2-in-1 Camera Lens Assembly Replacement: adım 3, 3 resimden 2. HP Sprocket 2-in-1 Camera Lens Assembly Replacement: adım 3, 3 resimden 3.
    • Remove two 2.5mm JIS #00 located on the small circuit board in view.
    • Use the Jimmy to remove the board after the screws have been removed.
    • Be careful not to crease or damage the ribbon cable.
  4. HP Sprocket 2-in-1 Camera Lens Assembly Replacement: adım 4, 3 resimden 1. HP Sprocket 2-in-1 Camera Lens Assembly Replacement: adım 4, 3 resimden 2. HP Sprocket 2-in-1 Camera Lens Assembly Replacement: adım 4, 3 resimden 3.
    • Remove two 2.5mm JIS #00 screws from the translucent plastic bracket.
    • One will be located beneath the ribbon cable.
    • Remove the translucent plastic bracket by hand.
  5. HP Sprocket 2-in-1 Camera Lens Assembly Replacement: adım 5, 2 resimden 1. HP Sprocket 2-in-1 Camera Lens Assembly Replacement: adım 5, 2 resimden 2.
    • Remove four 2.5mm JIS #00 screws from the beige casing.
  6. HP Sprocket 2-in-1 Camera Lens Assembly Replacement: adım 6, 3 resimden 1. HP Sprocket 2-in-1 Camera Lens Assembly Replacement: adım 6, 3 resimden 2. HP Sprocket 2-in-1 Camera Lens Assembly Replacement: adım 6, 3 resimden 3.
    • Use the iFixit opening tool to slowly work between the white and beige casing around the device.
    • Flip the device over and seperate the white casing from the rest of the device.
    • Be careful not to break the plastic while removing the case.
    • Gently remove the white casing as there is a ribbon cable connecting the two pieces.
  7. HP Sprocket 2-in-1 Camera Lens Assembly Replacement: adım 7, 1 resimden 1.
    • Carefully remove the ribbon cable that connects the flash to the outer casing.
  8. HP Sprocket 2-in-1 Camera Lens Assembly Replacement, Camera Lens Assembly: adım 8, 2 resimden 1. HP Sprocket 2-in-1 Camera Lens Assembly Replacement, Camera Lens Assembly: adım 8, 2 resimden 2.
    • Use the Japanese Industrial Standard J00 screwdriver to remove five 2.5mm screws.
    • One of the screws is below bronze tape. Move the tape slightly to get to the screw.
    • Remove the metal plate from the casing.
  9. HP Sprocket 2-in-1 Camera Lens Assembly Replacement: adım 9, 1 resimden 1.
    • Use an iFixit opening tool to pry the camera free from the device.
Sonuç
Paulo Warren
458 İtibar
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 322
