Giriş
Faulty Hard Drive
- If your device is demonstrating issues such as frequent error failures, corrupted data, files, and folders, and blue screen of death this may indicate there is a faulty hard drive. You will need to replace it. Use the guide below to help you replace your hard drive.
- Before you begin using this guide, make sure you have inspected your device thoroughly for similar symptoms mentioned above before making hardware changes.
- Make sure the device is not powered on before proceeding with the the guide steps and disconnected from any external power source.
- Second, proceed safely but rapidly to prevent any potential data loss using a new hard drive that better works for your system.
Neye ihtiyacın var
Check the battery port on your device and make sure it is clear of debris and pins are not bent or damaged.
Install the new battery into the port and press down gently.
Once installed and you have followed the battery manufacturer's instructions, turn your device on to its upright position and boot your device.
Remove battery by pushing the slide tabs towards the left.
Use a Phillips #1 screwdriver to remove the two 12.5 mm screws, four 5.5 mm screws, and six 7.25 mm screws.
Remove two corner panels along the ends of the battery slot and this will expose another set of screws (1 under each panel).
Remove the remaining six Phillips #1 7.25 mm screws hidden in the battery area and underneath the covers.
2 farklı kişi bu kılavuzu tamamladı.
