Ana içeriğe geç
HP Stream 11-d008TU Keyboard Assembly Replacement
Neye ihtiyacın var
  1. HP Stream 11-d008TU Keyboard Assembly Replacement, Rubber Feet Removal: adım 1, 3 resimden 1. HP Stream 11-d008TU Keyboard Assembly Replacement, Rubber Feet Removal: adım 1, 3 resimden 2. HP Stream 11-d008TU Keyboard Assembly Replacement, Rubber Feet Removal: adım 1, 3 resimden 3.
    • Use a prying tool to pry the 2 rubber feet off closest to the hinge of the device
    • Repeat this process for the other side of the device
    • The bottom rubber feet do not have hidden screws underneath them, and as such, they are unnecessary to remove
  2. HP Stream 11-d008TU Keyboard Assembly Replacement, Screw removal: adım 2, 2 resimden 1. HP Stream 11-d008TU Keyboard Assembly Replacement, Screw removal: adım 2, 2 resimden 2.
    • Remove the 11x 5mm Phillips PH-0 screws (circled)
  3. HP Stream 11-d008TU Keyboard Assembly Replacement, Keyboard Unclipping: adım 3, 3 resimden 1. HP Stream 11-d008TU Keyboard Assembly Replacement, Keyboard Unclipping: adım 3, 3 resimden 2. HP Stream 11-d008TU Keyboard Assembly Replacement, Keyboard Unclipping: adım 3, 3 resimden 3.
    • Use your finger to pry the outer blue shell over the keyboard
    • Continue this process around the edges of the device
    • You may have to use a prying tool to pry the harder edges such as around the I/O ports
    • Do not lift the keyboard once all the clips are undone, as there are still various cables connected
  4. HP Stream 11-d008TU Keyboard Assembly Replacement, Keyboard removal: adım 4, 3 resimden 1. HP Stream 11-d008TU Keyboard Assembly Replacement, Keyboard removal: adım 4, 3 resimden 2. HP Stream 11-d008TU Keyboard Assembly Replacement, Keyboard removal: adım 4, 3 resimden 3.
    • Disconnect the power button connector by peeling back the protective tape, using your fingernail to flip the white retaining clip back, and pulling the ribbon cable out
    • Disconnect the touchpad connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
    • Disconnect the keyboard connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
    • Your keyboard assembly is now safe to remove
Sonuç
Bir başkası bu kılavuzu tamamladı.
Joel Taylor
1.298 İtibar
8 adet Kılavuz yazıldı
Ekip
Australia Australia üyesi
Community
4 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 113
