Ana içeriğe geç
HP Stream 11-d010nr Motherboard Replacement
Neye ihtiyacın var
  1. HP Stream 11-d010nr Motherboard Replacement, Keyboard: adım 1, 2 resimden 1. HP Stream 11-d010nr Motherboard Replacement, Keyboard: adım 1, 2 resimden 2.
    • Unplug and turn off the HP Stream 11 before disassembling the device.
    • Pry off the two elliptical rubber inserts (one in each corner).
    • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
  2. HP Stream 11-d010nr Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the eleven 5.6 mm Phillips #1 screws.
  3. HP Stream 11-d010nr Motherboard Replacement: adım 3, 2 resimden 1. HP Stream 11-d010nr Motherboard Replacement: adım 3, 2 resimden 2.
    • Using an iFixit opening tool, pry open the case to separate the keyboard from the main body.
    • HP Stream 11s tend to be really difficult to open. If your device is not opening with a standard iFixit opening tool, use a nylon spudger, then the metal spudger, or a metal Jimmy as the last resort.
    • When using the metal spudger or Jimmy, be careful not to bring these tools into contact with any electronic components of the device as this can damage the device.
  4. HP Stream 11-d010nr Motherboard Replacement: adım 4, 1 resimden 1.
    • Slowly lift the keyboard as there are multiple ribbon cables that could easily be damaged if lifted with force.
    • Carefully lift the keyboard and locate the three ribbon cables connecting the main body of the laptop to the keyboard.
  5. HP Stream 11-d010nr Motherboard Replacement: adım 5, 3 resimden 1. HP Stream 11-d010nr Motherboard Replacement: adım 5, 3 resimden 2. HP Stream 11-d010nr Motherboard Replacement: adım 5, 3 resimden 3.
    • Using your fingernail, lift the flaps on the ZIF connectors that are securing the three ribbon cables.
    • Carefully disconnect the three ribbon cables.
  6. HP Stream 11-d010nr Motherboard Replacement: adım 6, 1 resimden 1.
    • Lift the keyboard out of the laptop to remove it from the device.
  7. HP Stream 11-d010nr Motherboard Replacement, Battery: adım 7, 1 resimden 1.
    • Remove any tape holding the battery connector in place.
    • Using your fingers, carefully unplug the battery.
  8. HP Stream 11-d010nr Motherboard Replacement: adım 8, 2 resimden 1. HP Stream 11-d010nr Motherboard Replacement: adım 8, 2 resimden 2.
    • Remove the four 3mm #000 Phillips screws holding the battery in place.
    • Carefully lift the battery out of the laptop.
  9. HP Stream 11-d010nr Motherboard Replacement, Motherboard: adım 9, 1 resimden 1.
    • Remove Wi-Fi card from the motherboard.
  10. HP Stream 11-d010nr Motherboard Replacement: adım 10, 1 resimden 1.
    • Use a Phillips #000 screwdriver to remove all 3 mm screws from the motherboard.
  11. HP Stream 11-d010nr Motherboard Replacement: adım 11, 1 resimden 1.
    • Gently lift the ribbon-cable ZIF tabs and remove all 6 cables from the motherboard.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 353
