Giriş
If you notice your laptop no longer keeping a charge, you may need to replace the battery. This device is kind of strange because the battery isn't one of the first things you remove. This makes it hazardous because you may accidentally turn on your laptop while taking it apart. So be careful when removing the cover and use caution around the power button to ensure you don't turn it on.
Neye ihtiyacın var
Pry off the two elliptical rubber inserts (one in each corner).
Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
Tilt the top of the keyboard plate up until you separate it from the base.
Tilt the keyboard toward you slowly but do not remove it, it is still connected with ribbon cables.
Remove any tape covering the battery connector.
Disconnect the battery cable from its socket on the motherboard.
22 farklı kişi bu kılavuzu tamamladı.
4Kılavuz Yorumları
Thank you for the guide. For us it was enough to unplug the battery and then plug it back in. The problem we encountered was that the capslock would blink on startup for the HP Stream 11.
Would this fix work for a HP notebook Model 11-N012NA. ?
Would this work for my House notebook PC 11-d011wm?
If I put the charger the thing will Will just start blinking
