Ana içeriğe geç
HP Stream 11-d020nr Lower Case Replacement
Neye ihtiyacın var
  1. HP Stream 11-d020nr Lower Case Replacement, Lower Case: adım 1, 3 resimden 1. HP Stream 11-d020nr Lower Case Replacement, Lower Case: adım 1, 3 resimden 2. HP Stream 11-d020nr Lower Case Replacement, Lower Case: adım 1, 3 resimden 3.
    • Before disassembly, unplug and power off the Stream 11.
    • Pry off the two elliptical rubber inserts (one in each corner).
    • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
  2. HP Stream 11-d020nr Lower Case Replacement: adım 2, 2 resimden 1. HP Stream 11-d020nr Lower Case Replacement: adım 2, 2 resimden 2.
    • Remove the eleven 5.6 mm Phillips #00 screws.
  3. HP Stream 11-d020nr Lower Case Replacement: adım 3, 3 resimden 1. HP Stream 11-d020nr Lower Case Replacement: adım 3, 3 resimden 2. HP Stream 11-d020nr Lower Case Replacement: adım 3, 3 resimden 3.
    • Turn the computer upright and lift the screen.
    • Carefully use a spudger to pry the plastic keyboard cover from the base.
    • When using the metal spudger, be careful not to press into the components underneath the keyboard cover. If possible, use a standard spudger or plastic opening tool to remove the keyboard cover.
    • Work the spudger around the cover to release the clips attaching the cover to the base.
    • Be patient when removing the cover, as there are many clips and it may take some time.
  4. HP Stream 11-d020nr Lower Case Replacement: adım 4, 3 resimden 1. HP Stream 11-d020nr Lower Case Replacement: adım 4, 3 resimden 2. HP Stream 11-d020nr Lower Case Replacement: adım 4, 3 resimden 3.
    • Disconnect the cable connecting the ClickPad to the base.
    • Remove the plastic keyboard cover.
    • The cover is attached to the ClickPad by a cable. Be careful not to lift the cover too far so you do not damage this cable.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ian Somerville
122 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 3-5, Wollert Spring 2016 USF Tampa, Team 3-5, Wollert Spring 2016 üyesi
USFT-WOLLERT-S16S3G5
5 Üyeler
19 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 1,698
