Ana içeriğe geç
HP Stream 11-d020nr Webcam Replacement
Neye ihtiyacın var
    1. HP Stream 11-d020nr Webcam Replacement, Lower Case: adım 1, 3 resimden 1. HP Stream 11-d020nr Webcam Replacement, Lower Case: adım 1, 3 resimden 2. HP Stream 11-d020nr Webcam Replacement, Lower Case: adım 1, 3 resimden 3.
      • Before disassembly, unplug and power off the Stream 11.
      • Pry off the two elliptical rubber inserts (one in each corner).
      • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
      FixBot'a Sor
      Yorum Ekle
    2. HP Stream 11-d020nr Webcam Replacement: adım 2, 2 resimden 1. HP Stream 11-d020nr Webcam Replacement: adım 2, 2 resimden 2.
      • Remove the eleven 5.6 mm Phillips #00 screws.
      FixBot'a Sor
      Yorum Ekle
    3. HP Stream 11-d020nr Webcam Replacement: adım 3, 3 resimden 1. HP Stream 11-d020nr Webcam Replacement: adım 3, 3 resimden 2. HP Stream 11-d020nr Webcam Replacement: adım 3, 3 resimden 3.
      • Turn the computer upright and lift the screen.
      • Carefully use a spudger to pry the plastic keyboard cover from the base.
      • When using the metal spudger, be careful not to press into the components underneath the keyboard cover. If possible, use a standard spudger or plastic opening tool to remove the keyboard cover.
      • Work the spudger around the cover to release the clips attaching the cover to the base.
      • Be patient when removing the cover, as there are many clips and it may take some time.
      FixBot'a Sor
      Yorum Ekle
    4. HP Stream 11-d020nr Webcam Replacement: adım 4, 3 resimden 1. HP Stream 11-d020nr Webcam Replacement: adım 4, 3 resimden 2. HP Stream 11-d020nr Webcam Replacement: adım 4, 3 resimden 3.
      • Disconnect the cable connecting the ClickPad to the base.
      • Remove the plastic keyboard cover.
      • The cover is attached to the ClickPad by a cable. Be careful not to lift the cover too far so you do not damage this cable.
      FixBot'a Sor
      Yorum Ekle
    1. HP Stream 11-d020nr Webcam Replacement, Keyboard: adım 5, 2 resimden 1. HP Stream 11-d020nr Webcam Replacement, Keyboard: adım 5, 2 resimden 2.
      • Tilt the top of the keyboard plate up until you separate it from the base.
      • Tilt the keyboard toward you slowly but do not remove it, it is still connected with ribbon cables.
      FixBot'a Sor
      Yorum Ekle
    2. HP Stream 11-d020nr Webcam Replacement: adım 6, 3 resimden 1. HP Stream 11-d020nr Webcam Replacement: adım 6, 3 resimden 2. HP Stream 11-d020nr Webcam Replacement: adım 6, 3 resimden 3.
      • Lift up the retaining flaps on the ZIF connectors securing the two keyboard ribbon cables.
      • After disengaging the connectors, gently unplug both ribbon cables.
      FixBot'a Sor
      Yorum Ekle
    1. HP Stream 11-d020nr Webcam Replacement, Lid: adım 7, 3 resimden 1. HP Stream 11-d020nr Webcam Replacement, Lid: adım 7, 3 resimden 2. HP Stream 11-d020nr Webcam Replacement, Lid: adım 7, 3 resimden 3.
      • Lift the black flap on the display cable ZIF connector.
      • After lifting the flap, gently pull the display cable from its socket.
      • Disconnect the wireless antenna from the wireless card.
      • Remove the four 2.2 mm Phillips #00 screws on the left and right sides of the laptop.
      FixBot'a Sor
      Yorum Ekle
    2. HP Stream 11-d020nr Webcam Replacement: adım 8, 3 resimden 1. HP Stream 11-d020nr Webcam Replacement: adım 8, 3 resimden 2. HP Stream 11-d020nr Webcam Replacement: adım 8, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Use tweezers to remove the screw covers from the lid.
      • Remove the two 2.2 mm Phillips #000 screws.
      • Use a plastic opening tool to disengage the front part of the lid.
      FixBot'a Sor
      Yorum Ekle
    1. HP Stream 11-d020nr Webcam Replacement, Webcam: adım 9, 1 resimden 1.
      • Use the tweezers to remove the wire connected to the webcam.
      FixBot'a Sor
      Yorum Ekle
    2. HP Stream 11-d020nr Webcam Replacement: adım 10, 1 resimden 1.
      • Use the tweezers to pull the webcam off of the frame.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Spenser Mason
1.781 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-5, Wollert Spring 2016 USF Tampa, Team 3-5, Wollert Spring 2016 üyesi
USFT-WOLLERT-S16S3G5
5 Üyeler
19 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 22
Her zaman: 719
