Ana içeriğe geç
HP Stream 11-y010nr Screen Replacement
Neye ihtiyacın var
  1. HP Stream 11-y010nr Screen Replacement, Keyboard: adım 1, 3 resimden 1. HP Stream 11-y010nr Screen Replacement, Keyboard: adım 1, 3 resimden 2. HP Stream 11-y010nr Screen Replacement, Keyboard: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Gently peel back the two rubber strips that cover the screws on backside of the computer with the needle nose tweezers.
    • Ensure the laptop is turned off.
  2. HP Stream 11-y010nr Screen Replacement: adım 2, 2 resimden 1. HP Stream 11-y010nr Screen Replacement: adım 2, 2 resimden 2.
    • Unscrew the seven 0.4mm screws on the backside of the laptop with the Phillips #0 Screwdriver.
  3. HP Stream 11-y010nr Screen Replacement: adım 3, 2 resimden 1. HP Stream 11-y010nr Screen Replacement: adım 3, 2 resimden 2.
    • Take the opening picks and push them into the seam between the keyboard and the laptop casing.
    • Go all the way around the laptop.
  4. HP Stream 11-y010nr Screen Replacement: adım 4, 1 resimden 1.
    • Once the cover is loose enough, lift the keyboard up to expose the wiring beneath.
    • Be careful not to pull too hard or fast as there are ribbon cables attached to the keyboard and trackpad.
  5. HP Stream 11-y010nr Screen Replacement: adım 5, 3 resimden 1. HP Stream 11-y010nr Screen Replacement: adım 5, 3 resimden 2. HP Stream 11-y010nr Screen Replacement: adım 5, 3 resimden 3.
    • Disconnect the three cables by lifting up on the locking tab of the ZIF connector and pulling the cables out with the needle nose tweezers.
    • Remove the keyboard.
  6. HP Stream 11-y010nr Screen Replacement, Screen: adım 6, 3 resimden 1. HP Stream 11-y010nr Screen Replacement, Screen: adım 6, 3 resimden 2. HP Stream 11-y010nr Screen Replacement, Screen: adım 6, 3 resimden 3.
    • Using your fingers or a spudger, pull the battery cable from its connector to disconnect power from the motherboard.
  7. HP Stream 11-y010nr Screen Replacement: adım 7, 2 resimden 1. HP Stream 11-y010nr Screen Replacement: adım 7, 2 resimden 2.
    • Insert iFixit opening picks into the edges of the screen to break the seal between the screen and bezel.
  8. HP Stream 11-y010nr Screen Replacement: adım 8, 3 resimden 1. HP Stream 11-y010nr Screen Replacement: adım 8, 3 resimden 2. HP Stream 11-y010nr Screen Replacement: adım 8, 3 resimden 3.
    • Peel the hinge up by sliding iFixit opening picks left to right along the hinge.
  9. HP Stream 11-y010nr Screen Replacement: adım 9, 3 resimden 1. HP Stream 11-y010nr Screen Replacement: adım 9, 3 resimden 2. HP Stream 11-y010nr Screen Replacement: adım 9, 3 resimden 3.
    • Remove the bezel by pulling upwards on the left bottom corner.
  10. HP Stream 11-y010nr Screen Replacement: adım 10, 2 resimden 1. HP Stream 11-y010nr Screen Replacement: adım 10, 2 resimden 2.
    • Disconnect the screen from the motherboard by pulling the display cable from its connector.
  11. HP Stream 11-y010nr Screen Replacement: adım 11, 1 resimden 1.
    • Unscrew the four 0.4mm screws surrounding the display using a Phillips #00 screwdriver.
  12. HP Stream 11-y010nr Screen Replacement: adım 12, 3 resimden 1. HP Stream 11-y010nr Screen Replacement: adım 12, 3 resimden 2. HP Stream 11-y010nr Screen Replacement: adım 12, 3 resimden 3.
    • Gently remove the screen from its holding and lay the screen down on the keyboard. It is still attached to the computer.
  13. HP Stream 11-y010nr Screen Replacement: adım 13, 3 resimden 1. HP Stream 11-y010nr Screen Replacement: adım 13, 3 resimden 2. HP Stream 11-y010nr Screen Replacement: adım 13, 3 resimden 3.
    • Take the tweezers and push up on the small connector to the left of the webcam.
  14. HP Stream 11-y010nr Screen Replacement: adım 14, 2 resimden 1. HP Stream 11-y010nr Screen Replacement: adım 14, 2 resimden 2.
    • Gently pull the cord out from around the screen area.
  15. HP Stream 11-y010nr Screen Replacement: adım 15, 2 resimden 1. HP Stream 11-y010nr Screen Replacement: adım 15, 2 resimden 2.
    • Remove the screen with the display cable attached.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 584
