Ana içeriğe geç
HP Stream 11-y010nr Trackpad Replacement
Neye ihtiyacın var
  1. HP Stream 11-y010nr Trackpad Replacement, Keyboard: adım 1, 3 resimden 1. HP Stream 11-y010nr Trackpad Replacement, Keyboard: adım 1, 3 resimden 2. HP Stream 11-y010nr Trackpad Replacement, Keyboard: adım 1, 3 resimden 3.
    • Gently peel back the two rubber strips that cover the screws on backside of the computer with the needle nose tweezers.
    • Ensure the laptop is turned off.
  2. HP Stream 11-y010nr Trackpad Replacement: adım 2, 2 resimden 1. HP Stream 11-y010nr Trackpad Replacement: adım 2, 2 resimden 2.
    • Unscrew the seven 0.4mm screws on the backside of the laptop with the Phillips #0 Screwdriver.
  3. HP Stream 11-y010nr Trackpad Replacement: adım 3, 2 resimden 1. HP Stream 11-y010nr Trackpad Replacement: adım 3, 2 resimden 2.
    • Take the opening picks and push them into the seam between the keyboard and the laptop casing.
    • Go all the way around the laptop.
  4. HP Stream 11-y010nr Trackpad Replacement: adım 4, 1 resimden 1.
    • Once the cover is loose enough, lift the keyboard up to expose the wiring beneath.
    • Be careful not to pull too hard or fast as there are ribbon cables attached to the keyboard and trackpad.
  5. HP Stream 11-y010nr Trackpad Replacement: adım 5, 3 resimden 1. HP Stream 11-y010nr Trackpad Replacement: adım 5, 3 resimden 2. HP Stream 11-y010nr Trackpad Replacement: adım 5, 3 resimden 3.
    • Disconnect the three cables by lifting up on the locking tab of the ZIF connector and pulling the cables out with the needle nose tweezers.
    • Remove the keyboard.
  6. HP Stream 11-y010nr Trackpad Replacement, Trackpad: adım 6, 2 resimden 1. HP Stream 11-y010nr Trackpad Replacement, Trackpad: adım 6, 2 resimden 2.
    • Take the keyboard and flip it over. It will look like the pictures.
    • Use the needle nose tweezer to take off protective tape covering the top left and top right screws.
  7. HP Stream 11-y010nr Trackpad Replacement: adım 7, 3 resimden 1. HP Stream 11-y010nr Trackpad Replacement: adım 7, 3 resimden 2. HP Stream 11-y010nr Trackpad Replacement: adım 7, 3 resimden 3.
    • Unscrew the three 0.2mm top screws with the Phillips #00 Screwdriver.
  8. HP Stream 11-y010nr Trackpad Replacement: adım 8, 3 resimden 1. HP Stream 11-y010nr Trackpad Replacement: adım 8, 3 resimden 2. HP Stream 11-y010nr Trackpad Replacement: adım 8, 3 resimden 3.
    • Unscrew the three 0.3mm screws holding the bottom bracket with the Phillips #00 Screwdriver.
  9. HP Stream 11-y010nr Trackpad Replacement: adım 9, 3 resimden 1. HP Stream 11-y010nr Trackpad Replacement: adım 9, 3 resimden 2. HP Stream 11-y010nr Trackpad Replacement: adım 9, 3 resimden 3.
    • Lift up on the bracket and remove the bracket by lifting up on the metal end as shown.
  10. HP Stream 11-y010nr Trackpad Replacement: adım 10, 3 resimden 1. HP Stream 11-y010nr Trackpad Replacement: adım 10, 3 resimden 2. HP Stream 11-y010nr Trackpad Replacement: adım 10, 3 resimden 3.
    • The trackpad is now free to be removed.
    • Remove the trackpad by gently pulling up on the metal piece on the bottom left corner of the trackpad.
Sonuç
To reassemble your device, follow these instructions.
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 5
Her zaman: 253
