Ana içeriğe geç
HP Stream 11-y010nr Webcam Replacement
Neye ihtiyacın var
  1. HP Stream 11-y010nr Webcam Replacement, Keyboard: adım 1, 3 resimden 1. HP Stream 11-y010nr Webcam Replacement, Keyboard: adım 1, 3 resimden 2. HP Stream 11-y010nr Webcam Replacement, Keyboard: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Gently peel back the two rubber strips that cover the screws on backside of the computer with the needle nose tweezers.
    • Ensure the laptop is turned off.
  2. HP Stream 11-y010nr Webcam Replacement: adım 2, 2 resimden 1. HP Stream 11-y010nr Webcam Replacement: adım 2, 2 resimden 2.
    • Unscrew the seven 0.4mm screws on the backside of the laptop with the Phillips #0 Screwdriver.
  3. HP Stream 11-y010nr Webcam Replacement: adım 3, 2 resimden 1. HP Stream 11-y010nr Webcam Replacement: adım 3, 2 resimden 2.
    • Take the opening picks and push them into the seam between the keyboard and the laptop casing.
    • Go all the way around the laptop.
  4. HP Stream 11-y010nr Webcam Replacement: adım 4, 1 resimden 1.
    • Once the cover is loose enough, lift the keyboard up to expose the wiring beneath.
    • Be careful not to pull too hard or fast as there are ribbon cables attached to the keyboard and trackpad.
  5. HP Stream 11-y010nr Webcam Replacement: adım 5, 3 resimden 1. HP Stream 11-y010nr Webcam Replacement: adım 5, 3 resimden 2. HP Stream 11-y010nr Webcam Replacement: adım 5, 3 resimden 3.
    • Disconnect the three cables by lifting up on the locking tab of the ZIF connector and pulling the cables out with the needle nose tweezers.
    • Remove the keyboard.
  6. HP Stream 11-y010nr Webcam Replacement, Webcam: adım 6, 3 resimden 1. HP Stream 11-y010nr Webcam Replacement, Webcam: adım 6, 3 resimden 2. HP Stream 11-y010nr Webcam Replacement, Webcam: adım 6, 3 resimden 3.
    • Use your fingers or a spudger to pull the battery cable out from its connector.
  7. HP Stream 11-y010nr Webcam Replacement: adım 7, 2 resimden 1. HP Stream 11-y010nr Webcam Replacement: adım 7, 2 resimden 2.
    • Insert iFixit opening picks into the edges of the screen to break seal between the screen and bezel.
  8. HP Stream 11-y010nr Webcam Replacement: adım 8, 3 resimden 1. HP Stream 11-y010nr Webcam Replacement: adım 8, 3 resimden 2. HP Stream 11-y010nr Webcam Replacement: adım 8, 3 resimden 3.
    • Peel the hinge up by sliding the iFixit opening picks left to right along the hinge.
  9. HP Stream 11-y010nr Webcam Replacement: adım 9, 3 resimden 1. HP Stream 11-y010nr Webcam Replacement: adım 9, 3 resimden 2. HP Stream 11-y010nr Webcam Replacement: adım 9, 3 resimden 3.
    • Remove the plastic bezel by pulling upwards on the bottom left corner.
  10. HP Stream 11-y010nr Webcam Replacement: adım 10, 3 resimden 1. HP Stream 11-y010nr Webcam Replacement: adım 10, 3 resimden 2. HP Stream 11-y010nr Webcam Replacement: adım 10, 3 resimden 3.
    • Take the tweezers and push up on the small connector to the left of the webcam.
  11. HP Stream 11-y010nr Webcam Replacement: adım 11, 3 resimden 1. HP Stream 11-y010nr Webcam Replacement: adım 11, 3 resimden 2. HP Stream 11-y010nr Webcam Replacement: adım 11, 3 resimden 3.
    • Take an iFixit opening pick and slowly remove the webcam by sliding it under the camera and prying the entire strip from the case.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 11
Her zaman: 173
