Ana içeriğe geç
HP Stream 11-y012nr Audio Jack Replacement
Neye ihtiyacın var
  1. HP Stream 11-y012nr Audio Jack Replacement, Audio Jack: adım 1, 3 resimden 1. HP Stream 11-y012nr Audio Jack Replacement, Audio Jack: adım 1, 3 resimden 2. HP Stream 11-y012nr Audio Jack Replacement, Audio Jack: adım 1, 3 resimden 3.
    • Before disassembly, power off the device and unplug it from the charger.
    • Turn the laptop over to access the lower case.
    • Using a metal spudger, remove the two horizontal screw covers.
  2. HP Stream 11-y012nr Audio Jack Replacement: adım 2, 2 resimden 1. HP Stream 11-y012nr Audio Jack Replacement: adım 2, 2 resimden 2.
    • Remove the seven 5.6 mm Phillips #00 screws.
  3. HP Stream 11-y012nr Audio Jack Replacement: adım 3, 3 resimden 1. HP Stream 11-y012nr Audio Jack Replacement: adım 3, 3 resimden 2. HP Stream 11-y012nr Audio Jack Replacement: adım 3, 3 resimden 3.
    • When using the metal spudger, be careful to not press into the components and circuits under the keyboard .
    • Turn the laptop upright and lift the screen.
    • Use the metal spudger to carefully pry the plastic keyboard from the base of the laptop.
    • Work the spudger carefully and slowly around the cover to release the clips holding it together. Be patient since there are a lot of clips attaching the laptop base to the keyboard.
  4. HP Stream 11-y012nr Audio Jack Replacement: adım 4, 3 resimden 1. HP Stream 11-y012nr Audio Jack Replacement: adım 4, 3 resimden 2. HP Stream 11-y012nr Audio Jack Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • The cover is attached by multiple cables. Be careful not to lift the cover too far so you do not damage these cables.
    • Using tweezers, unplug the three cables attached to the keyboard. To do so you will find where the wires end (the three red marks). The next step is to use tweezers or your fingers to pinch the plastic piece holding the wires, and gently pull the piece out. After that it should disconnect.
    • Remove the plastic keyboard cover.
  5. HP Stream 11-y012nr Audio Jack Replacement: adım 5, 2 resimden 1. HP Stream 11-y012nr Audio Jack Replacement: adım 5, 2 resimden 2.
    • Remove the two 5.6 mm Phillips #00 screws.
  6. HP Stream 11-y012nr Audio Jack Replacement: adım 6, 2 resimden 1. HP Stream 11-y012nr Audio Jack Replacement: adım 6, 2 resimden 2.
    • Using tweezers or a nylon spudger, gently unplug the cable connector.
  7. HP Stream 11-y012nr Audio Jack Replacement: adım 7, 1 resimden 1.
    • Remove the audio jack.
Sonuç
Johnny Shen
196 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team S18-G8, Lore Winter 2019 UC Davis, Team S18-G8, Lore Winter 2019 üyesi
UCD-LORE-W19S18G8
3 Üyeler
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 9
Her zaman: 399
