Ana içeriğe geç
HP Stream 13 Battery Replacement
Videoya Genel Bakış
  1. HP Stream 13 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over
  2. HP Stream 13 Battery Replacement: adım 2, 2 resimden 1. HP Stream 13 Battery Replacement: adım 2, 2 resimden 2.
    • Remove the five screw covers across the back edge of the laptop
    • Remove the 13 screws that hold the base in place.
  3. HP Stream 13 Battery Replacement: adım 3, 1 resimden 1.
    • Carefully pry up around the edges of the laptop. Take your time around the ports as they can easily get damaged.
  4. HP Stream 13 Battery Replacement: adım 4, 2 resimden 1. HP Stream 13 Battery Replacement: adım 4, 2 resimden 2.
    • Slowly lift the top case/keyboard upwards and disconnect the three ribbon cables.
  5. HP Stream 13 Battery Replacement: adım 5, 2 resimden 1. HP Stream 13 Battery Replacement: adım 5, 2 resimden 2.
    • Disconnect the battery from the main board.
    • Unscrew the 8 screws holding the battery in place.
  6. HP Stream 13 Battery Replacement: adım 6, 1 resimden 1.
    • Lift the battery out and you're done.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nick Myers
5.156 İtibar
30 adet Kılavuz yazıldı
1Rehber Yorum
Where can I find a replacement battery for hp stream notebook pc 13 c12Onr. I have looked everywhere and no luck. Is there another one that is compatible? Thanks!
Sarah - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 25
Her zaman: 1,651
