Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
HP Stream 13-c002dx Battery Replacement
Neye ihtiyacın var
  1. HP Stream 13-c002dx Battery Replacement, Keyboard: adım 1, 2 resimden 1. HP Stream 13-c002dx Battery Replacement, Keyboard: adım 1, 2 resimden 2.
    • Begin by placing your laptop on a clean surface such as a table and away from any liquids which may spill and damage components.
    • Flip the laptop over so the bottom is facing up.
    • Use your Phillips #0 screwdriver to remove the eleven visible 5 mm screws on the back of the laptop.
    • There are some screws underneath the rubber feet. Use a spudger to remove them and gain access.
    • Unscrew the two remaining 2.5mm screws. Keep these screws separate from the first eleven 5mm screws.
  2. HP Stream 13-c002dx Battery Replacement: adım 2, 3 resimden 1. HP Stream 13-c002dx Battery Replacement: adım 2, 3 resimden 2. HP Stream 13-c002dx Battery Replacement: adım 2, 3 resimden 3.
    • Flip the laptop back over so it's right side up and open the screen.
    • Using a spudger, separate the keyboard surface from the bottom of the laptop.
    • While lifting the keyboard surface from the bottom, you will notice three cables still attaching them together. Gently unplug each of these cables from the motherboard.
    • Remove the keyboard assembly.
  3. HP Stream 13-c002dx Battery Replacement, Battery: adım 3, 1 resimden 1.
    • You will notice various screws in the battery with letters A or B next to them. Using your Philips screwdriver, remove each of these 5mm screws and keep the A and B screws separate for reassembly.
  4. HP Stream 13-c002dx Battery Replacement: adım 4, 2 resimden 1. HP Stream 13-c002dx Battery Replacement: adım 4, 2 resimden 2.
    • Coming from the upper middle of the battery, there are cables which connect the battery to the motherboard. Gently remove this group of cables from the socket that it is in on the motherboard.
    • Now lift the battery out are ready to insert the replacement battery.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 17
Her zaman: 3,049
