Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Flip the laptop over so the bottom is facing up.
Use your Phillips #0 screwdriver to remove the eleven visible 5 mm screws on the back of the laptop.
Unscrew the two remaining 2.5mm screws. Keep these screws separate from the first eleven 5mm screws.
Using a spudger, separate the keyboard surface from the bottom of the laptop.
While lifting the keyboard surface from the bottom, you will notice three cables still attaching them together. Gently unplug each of these cables from the motherboard.
Remove the keyboard assembly.
Use the Phillips #0 to remove four screws from the top of the battery labeled A.
Use the Phillips #0 screwdriver to remove four screws labeled holding the battery to the case.
Coming from the upper middle of the battery, there are cables which connect the battery to the motherboard. Gently remove this group of cables from the socket that it is in on the motherboard.
Lift the battery out.
2 farklı kişi bu kılavuzu tamamladı.
