Ana içeriğe geç
HP Stream 13-c002dx Keyboard Replacement
Neye ihtiyacın var
  1. HP Stream 13-c002dx Keyboard Replacement, Keyboard: adım 1, 2 resimden 1. HP Stream 13-c002dx Keyboard Replacement, Keyboard: adım 1, 2 resimden 2.
    • Begin by placing your laptop on a clean surface such as a table and away from any liquids which may spill and damage components.
    • Flip the laptop over so the bottom is facing up.
    • Use your Phillips #0 screwdriver to remove the eleven visible 5 mm screws on the back of the laptop.
    • There are some screws underneath the rubber feet. Use a spudger to remove them and gain access.
    • Unscrew the two remaining 2.5mm screws. Keep these screws separate from the first eleven 5mm screws.
  2. HP Stream 13-c002dx Keyboard Replacement: adım 2, 3 resimden 1. HP Stream 13-c002dx Keyboard Replacement: adım 2, 3 resimden 2. HP Stream 13-c002dx Keyboard Replacement: adım 2, 3 resimden 3.
    • Flip the laptop back over so it's right side up and open the screen.
    • Using a spudger, separate the keyboard surface from the bottom of the laptop.
    • While lifting the keyboard surface from the bottom, you will notice three cables still attaching them together. Gently unplug each of these cables from the motherboard.
    • Remove the keyboard assembly.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 761
