Ana içeriğe geç
Giriş
This guide includes laptop disassembly to gain access to the internal components and motherboard replacement.
  1. Begin by placing your laptop on a clean surface such as a table and away from any liquids which may spill and damage components. Flip the laptop over so the bottom is facing up and use your Philips #0 screwdriver to remove the 11 visible 5mm screws on the back.
    • Begin by placing your laptop on a clean surface such as a table and away from any liquids which may spill and damage components.
    • Flip the laptop over so the bottom is facing up and use your Philips #0 screwdriver to remove the 11 visible 5mm screws on the back.
    • Remove the rubber feet on the bottom of the laptop closest to the screen hinge to gain access to the remaining 2 5mm screws. Keep these screws separate from the first 11.
  2. Flip the laptop back over onto its normal side up and raise the screen. Using the metal spudger, separate the keyboard surface from the bottom of the laptop. While lifting the keyboard surface from the bottom, you will notice 3 cables still attaching them together. Gently unplug each of these cables from the motherboard. With the screen and keyboard parts of the laptop removed, you have access to the laptops internal components.
    • Flip the laptop back over onto its normal side up and raise the screen. Using the metal spudger, separate the keyboard surface from the bottom of the laptop.
    • While lifting the keyboard surface from the bottom, you will notice 3 cables still attaching them together. Gently unplug each of these cables from the motherboard.
    • With the screen and keyboard parts of the laptop removed, you have access to the laptops internal components.
  3. You will notice various screws in the battery with letters A or B next to them. Using your Philips screwdriver, remove each of these 5mm screws and keep the A and B screws separate for reassembly.
    • You will notice various screws in the battery with letters A or B next to them. Using your Philips screwdriver, remove each of these 5mm screws and keep the A and B screws separate for reassembly.
  4. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  5. Coming from the upper middle of the battery, there are cables which connect the battery to the motherboard. Gently remove this group of cables from the socket that it is in on the motherboard. Now lift the battery out are ready to insert the replacement battery.
    • Coming from the upper middle of the battery, there are cables which connect the battery to the motherboard. Gently remove this group of cables from the socket that it is in on the motherboard.
    • Now lift the battery out are ready to insert the replacement battery.
  6. Inside the laptop you will notice the wireless card located in the upper middle. This will be what you are replacing. Attached to the wifi card is a black wire that must be removed. Using your hand, lift gently on the wire as close as you can to where it connects to the wifi card. Once the wire is removed, set it aside so it does not get damaged.
    • Inside the laptop you will notice the wireless card located in the upper middle. This will be what you are replacing.
    • Attached to the wifi card is a black wire that must be removed. Using your hand, lift gently on the wire as close as you can to where it connects to the wifi card.
    • Once the wire is removed, set it aside so it does not get damaged.
  7. Next remove the screw holding the wireless card in place. With the screw removed, gently pull back the wifi card and then lift it out of the laptop.  You are now ready to insert the new wireless card. With the screw removed, gently pull back the wifi card and then lift it out of the laptop.  You are now ready to insert the new wireless card.
    • Next remove the screw holding the wireless card in place.
    • With the screw removed, gently pull back the wifi card and then lift it out of the laptop. You are now ready to insert the new wireless card.
  8. Once you have access to the internals, remove the wires and wifi card connected to the motherboard. To remove the upper wire connection, flip the tab holding it into the motherboard, then remove the wire gently. To remove the wire strand connection, flip the tab shown and then remove the wire strand.
    • Once you have access to the internals, remove the wires and wifi card connected to the motherboard.
    • To remove the upper wire connection, flip the tab holding it into the motherboard, then remove the wire gently.
    • To remove the wire strand connection, flip the tab shown and then remove the wire strand.
  9. With all the wired connections removed, now unscrew the screws holding the motherboard in place. With all the wired connections removed, now unscrew the screws holding the motherboard in place.
    • With all the wired connections removed, now unscrew the screws holding the motherboard in place.
  10. Now, once gently pry up on the right side of the motherboard and then lift the motherboard out. You are now ready to replace the motherboard. Now, once gently pry up on the right side of the motherboard and then lift the motherboard out. You are now ready to replace the motherboard.
    • Now, once gently pry up on the right side of the motherboard and then lift the motherboard out. You are now ready to replace the motherboard.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 3
Son 30 Gün: 17
Her zaman: 219
