Ana içeriğe geç
HP Stream 13-c002dx Wireless Card Replacement
Neye ihtiyacın var
  1. HP Stream 13-c002dx Wireless Card  Replacement, Keyboard: adım 1, 2 resimden 1. HP Stream 13-c002dx Wireless Card  Replacement, Keyboard: adım 1, 2 resimden 2.
    • Begin by placing your laptop on a clean surface such as a table and away from any liquids which may spill and damage components.
    • Flip the laptop over so the bottom is facing up.
    • Use your Phillips #0 screwdriver to remove the eleven visible 5 mm screws on the back of the laptop.
    • There are some screws underneath the rubber feet. Use a spudger to remove them and gain access.
    • Unscrew the two remaining 2.5mm screws. Keep these screws separate from the first eleven 5mm screws.
    FixBot'a Sor
    Yorum Ekle
  2. HP Stream 13-c002dx Wireless Card  Replacement: adım 2, 3 resimden 1. HP Stream 13-c002dx Wireless Card  Replacement: adım 2, 3 resimden 2. HP Stream 13-c002dx Wireless Card  Replacement: adım 2, 3 resimden 3.
    • Flip the laptop back over so it's right side up and open the screen.
    • Using a spudger, separate the keyboard surface from the bottom of the laptop.
    • While lifting the keyboard surface from the bottom, you will notice three cables still attaching them together. Gently unplug each of these cables from the motherboard.
    • Remove the keyboard assembly.
    FixBot'a Sor
    Yorum Ekle
  3. HP Stream 13-c002dx Wireless Card  Replacement, Wireless Card: adım 3, 3 resimden 1. HP Stream 13-c002dx Wireless Card  Replacement, Wireless Card: adım 3, 3 resimden 2. HP Stream 13-c002dx Wireless Card  Replacement, Wireless Card: adım 3, 3 resimden 3.
    • Inside the laptop you will notice the wireless card located in the upper middle. This will be what you are replacing.
    • Attached to the Wi-Fi card is a black wire that must be removed. Using your hand, lift gently on the wire as close as you can to where it connects to the Wi-Fi card.
    • Once the wire is removed, set it aside so it does not get damaged.
    FixBot'a Sor
    Yorum Ekle
  4. HP Stream 13-c002dx Wireless Card  Replacement: adım 4, 3 resimden 1. HP Stream 13-c002dx Wireless Card  Replacement: adım 4, 3 resimden 2. HP Stream 13-c002dx Wireless Card  Replacement: adım 4, 3 resimden 3.
    • Remove the screw holding the wireless card in place.
    • With the screw removed, gently pull back the Wi-Fi card and then lift it out of the laptop. You are now ready to insert the new wireless card.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 33
Her zaman: 1,789
