Ana içeriğe geç
HP Stream 13-c010nr Battery Replacement
Neye ihtiyacın var
  1. HP Stream 13-c010nr Battery Replacement, laptop: adım 1, 1 resimden 1.
    • Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  2. HP Stream 13-c010nr Battery Replacement: adım 2, 2 resimden 1. HP Stream 13-c010nr Battery Replacement: adım 2, 2 resimden 2.
    • Remove the thirteen 5mm Phillips #0 screws from the bottom case.
    FixBot'a Sor
    Yorum Ekle
  3. HP Stream 13-c010nr Battery Replacement: adım 3, 2 resimden 1. HP Stream 13-c010nr Battery Replacement: adım 3, 2 resimden 2.
    • Flip the laptop over and open it up.
    • Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
    • Lift up the keyboard.
    • Ribbon cables still connect the two pieces.
    FixBot'a Sor
    Yorum Ekle
  4. HP Stream 13-c010nr Battery Replacement: adım 4, 1 resimden 1.
    • Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
    • Pull up the ribbon cables from their sockets.
    FixBot'a Sor
    Yorum Ekle
  5. HP Stream 13-c010nr Battery Replacement, Battery: adım 5, 2 resimden 1. HP Stream 13-c010nr Battery Replacement, Battery: adım 5, 2 resimden 2.
    • Remove the eight 5mm Phillips #0 screws from the battery.
    • Disconnect the battery from the motherboard.
    • Pull the battery up and out of the laptop.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Keegan Lapham
759 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G3, Cagle Spring 2018 USF Tampa, Team S1-G3, Cagle Spring 2018 üyesi
USFT-CAGLE-S18S1G3
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 49
Her zaman: 2,190
