Ana içeriğe geç
HP Stream 13-c010nr Disassembly
Neye ihtiyacın var
  1. HP Stream 13-c010nr Disassembly, HP Stream 13-c010nr Disassembly: adım 1, 1 resimden 1.
    • Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
  2. HP Stream 13-c010nr Disassembly: adım 2, 2 resimden 1. HP Stream 13-c010nr Disassembly: adım 2, 2 resimden 2.
    • Remove the thirteen 5mm Phillips #0 screws from the bottom case.
  3. HP Stream 13-c010nr Disassembly: adım 3, 2 resimden 1. HP Stream 13-c010nr Disassembly: adım 3, 2 resimden 2.
    • Flip the laptop over and open it up.
    • Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
    • Lift up the keyboard.
    • Ribbon cables still connect the two pieces.
  4. HP Stream 13-c010nr Disassembly: adım 4, 1 resimden 1.
    • Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
    • Pull up the ribbon cables from their sockets.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Keegan Lapham
759 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G3, Cagle Spring 2018 USF Tampa, Team S1-G3, Cagle Spring 2018 üyesi
USFT-CAGLE-S18S1G3
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 74
Her zaman: 3,546
