Ana içeriğe geç
HP Stream 13-c010nr Display Replacement
Neye ihtiyacın var
  1. HP Stream 13-c010nr Display Replacement, laptop: adım 1, 1 resimden 1.
    • Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  2. HP Stream 13-c010nr Display Replacement: adım 2, 2 resimden 1. HP Stream 13-c010nr Display Replacement: adım 2, 2 resimden 2.
    • Remove the thirteen 5mm Phillips #0 screws from the bottom case.
    FixBot'a Sor
    Yorum Ekle
  3. HP Stream 13-c010nr Display Replacement: adım 3, 2 resimden 1. HP Stream 13-c010nr Display Replacement: adım 3, 2 resimden 2.
    • Flip the laptop over and open it up.
    • Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
    • Lift up the keyboard.
    • Ribbon cables still connect the two pieces.
    FixBot'a Sor
    Yorum Ekle
  4. HP Stream 13-c010nr Display Replacement: adım 4, 1 resimden 1.
    • Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
    • Pull up the ribbon cables from their sockets.
    FixBot'a Sor
    Yorum Ekle
  5. HP Stream 13-c010nr Display Replacement, Display: adım 5, 1 resimden 1.
    • Remove the screw covers from the bottom corner edges of the screen.
    FixBot'a Sor
    Yorum Ekle
  6. HP Stream 13-c010nr Display Replacement: adım 6, 2 resimden 1. HP Stream 13-c010nr Display Replacement: adım 6, 2 resimden 2.
    • Remove the two 5mm Phillips #0 screws from the screen bezel.
    FixBot'a Sor
    Yorum Ekle
  7. HP Stream 13-c010nr Display Replacement: adım 7, 2 resimden 1. HP Stream 13-c010nr Display Replacement: adım 7, 2 resimden 2.
    • Wedge the plastic opening tool between the frame of the screen and the casing of the laptop.
    • Pry upwards on the plastic opening tool to separate the bezel from the display.
    FixBot'a Sor
    Yorum Ekle
  8. HP Stream 13-c010nr Display Replacement: adım 8, 1 resimden 1.
    • Remove the four 3mm Phillips #0 screws from the screen.
    FixBot'a Sor
    Yorum Ekle
  9. HP Stream 13-c010nr Display Replacement: adım 9, 1 resimden 1.
    • Use a spudger to flip up the retaining flap on the screen ribbon cable ZIF socket.
    • Pull the ribbon cable out of the ZIF socket.
    • Remove the screen.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Keegan Lapham
759 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G3, Cagle Spring 2018 USF Tampa, Team S1-G3, Cagle Spring 2018 üyesi
USFT-CAGLE-S18S1G3
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 1,051
