Ana içeriğe geç
HP Stream 13-c110nr Display Replacement
Neye ihtiyacın var
  1. HP Stream 13-c110nr Display Replacement, Keyboard Assembly: adım 1, 1 resimden 1.
    • Close the device.
    • Remove AC adapter plug from electrical outlet.
    • Remove AC adapter from device.
    • Turn the device off.
    • Unplug all external devices from device.
    • If you are unsure whether the computer is off or in hibernation mode, start the computer and then shutdown the operating system.
  2. HP Stream 13-c110nr Display Replacement: adım 2, 1 resimden 1.
    • Turn the device upside down with the back facing towards you.
  3. HP Stream 13-c110nr Display Replacement: adım 3, 3 resimden 1. HP Stream 13-c110nr Display Replacement: adım 3, 3 resimden 2. HP Stream 13-c110nr Display Replacement: adım 3, 3 resimden 3.
    • Use a pick to remove the two (2) large computer feet along the back edge of the device.
    • Use a pick to remove the two (2) small computer feet.
    • Use a pick to remove the one (1) screw cover.
    • Place rubber computer feet in safe place for reassembly.
  4. HP Stream 13-c110nr Display Replacement: adım 4, 3 resimden 1. HP Stream 13-c110nr Display Replacement: adım 4, 3 resimden 2. HP Stream 13-c110nr Display Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    • Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws.
    • Place the thirteen (13) screws on magnetic mat for reassembly.
  5. HP Stream 13-c110nr Display Replacement: adım 5, 1 resimden 1.
    • Turn the device over with the front facing towards you.
    • Open the device as shown.
  6. HP Stream 13-c110nr Display Replacement: adım 6, 3 resimden 1. HP Stream 13-c110nr Display Replacement: adım 6, 3 resimden 2. HP Stream 13-c110nr Display Replacement: adım 6, 3 resimden 3.
    • Insert the Spudger between the Top Cover and Bottom Cover to lift the front edge until it separates from the Bottom Cover.
    • Do not completely remove the Keyboard/Top cover from the Bottom cover yet.
  7. HP Stream 13-c110nr Display Replacement: adım 7, 1 resimden 1.
    • Disconnect the Touchpad cable.
  8. HP Stream 13-c110nr Display Replacement: adım 8, 2 resimden 1. HP Stream 13-c110nr Display Replacement: adım 8, 2 resimden 2.
    • Disconnect the Keyboard Cable.
  9. HP Stream 13-c110nr Display Replacement: adım 9, 2 resimden 1. HP Stream 13-c110nr Display Replacement: adım 9, 2 resimden 2.
    • Disconnect the Power connector cable.
  10. HP Stream 13-c110nr Display Replacement: adım 10, 1 resimden 1.
    • Remove the Keyboard/Top Cover from the device.
  11. HP Stream 13-c110nr Display Replacement, Display Assembly: adım 11, 1 resimden 1.
    • Disconnect the Display Cable from the System Board.
  12. HP Stream 13-c110nr Display Replacement: adım 12, 3 resimden 1. HP Stream 13-c110nr Display Replacement: adım 12, 3 resimden 2. HP Stream 13-c110nr Display Replacement: adım 12, 3 resimden 3.
    • Remove the four (4) Phillips P0 PM2.5x4.5 mm screws from the screen retaining brackets.
    • Place the four (4) screws on the magnetic mat for reassembly.
  13. HP Stream 13-c110nr Display Replacement: adım 13, 2 resimden 1. HP Stream 13-c110nr Display Replacement: adım 13, 2 resimden 2.
    • Peel off two (2) stickers located at the bottom corners of the display assembly.
    • Place two (2) stickers in safe place for reassembly.
  14. HP Stream 13-c110nr Display Replacement: adım 14, 3 resimden 1. HP Stream 13-c110nr Display Replacement: adım 14, 3 resimden 2. HP Stream 13-c110nr Display Replacement: adım 14, 3 resimden 3.
    • Remove the two (2) Phillips P0 PM2.5x2.0 mm screws.
    • Place the two (2) screws on the magnetic mat for reassembly.
  15. HP Stream 13-c110nr Display Replacement: adım 15, 3 resimden 1. HP Stream 13-c110nr Display Replacement: adım 15, 3 resimden 2. HP Stream 13-c110nr Display Replacement: adım 15, 3 resimden 3.
    • Use a pick to pry off the display cover from the display.
  16. HP Stream 13-c110nr Display Replacement: adım 16, 1 resimden 1.
    • Remove the Display Assembly.
  17. HP Stream 13-c110nr Display Replacement: adım 17, 2 resimden 1. HP Stream 13-c110nr Display Replacement: adım 17, 2 resimden 2.
    • Remove the four (4) Phillips P0 PM2.5x4.5 mm screws.
    • Place four (4) screws on magnetic mat for reassembly.
    • Remove the two (2) Phillips P0 PM2.5x3.0 mm screws.
    • Place two (2) screws on magnetic mat for reassembly.
  18. HP Stream 13-c110nr Display Replacement: adım 18, 1 resimden 1.
    • Separate display from back cover
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 430
