Giriş
Since HP Stream 7 is a tablet and has many small parts. Be careful when removing/replacing parts. Do not force anything to avoid breaking device material.
Neye ihtiyacın var
Make sure the tablet is powered off before beginning.
Gently run the plastic opening tool or your fingernails around the tablet to pry the Back Cover from the tablet.
Disconnect the battery from the motherboard, but leave the battery on the display panel (unless you have already taken it off).
Disconnect the motherboard from the rear-facing camera, the front-facing camera, the antenna, the power button board, the screen, and the display panel using your spudger.
After removing the motherboard, unscrew the four 2.5 mm Phillips 000 screws from the display panel.
6 farklı kişi bu kılavuzu tamamladı.
6Kılavuz Yorumları
Same question but no answer !
Where can anyone find replacement screen online ??
We're I can buy the replacement screen?
