Ana içeriğe geç
HP Stream 7 Screen Replacement
Neye ihtiyacın var
    1. HP Stream 7  Screen Replacement, Battery: adım 1, 2 resimden 1. HP Stream 7  Screen Replacement, Battery: adım 1, 2 resimden 2.
      • Make sure the tablet is powered off before beginning.
      • Gently run the plastic opening tool or your fingernails around the tablet to pry the Back Cover from the tablet.
      FixBot'a Sor
      Yorum Ekle
    2. HP Stream 7  Screen Replacement: adım 2, 2 resimden 1. HP Stream 7  Screen Replacement: adım 2, 2 resimden 2.
      • Remove the eight 5 mm Phillips 000 screws.
      • Gently run the plastic opening tool around the seam to pry the mid back cover from the tablet.
      FixBot'a Sor
      Yorum Ekle
    3. HP Stream 7  Screen Replacement: adım 3, 2 resimden 1. HP Stream 7  Screen Replacement: adım 3, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Using tweezers, gently pull the battery connector towards the battery to remove it from the System Board.
      • Pull the blue tabs (Not Shown) out from the tablet at an angle to remove the tape underneath the Battery.
      • If you broke both tabs, scrape the tape and Battery off.
      • Scraping off the Battery will damage it. If you are replacing another part, leave the Battery on the display panel.
      FixBot'a Sor
      Yorum Ekle
    1. HP Stream 7  Screen Replacement, Motherboard Replacement: adım 4, 1 resimden 1.
      • Disconnect the battery from the motherboard, but leave the battery on the display panel (unless you have already taken it off).
      • Disconnect the motherboard from the rear-facing camera, the front-facing camera, the antenna, the power button board, the screen, and the display panel using your spudger.
      • The cable connected to the display is adhered to the panel, so be careful when removing the cable (like most things here).
      • If you are inexperienced with disconnecting everything, "Recognizing and Disconnecting Cable Connectors" is a helpful ifixit guide.
      FixBot'a Sor
      Yorum Ekle
    2. HP Stream 7  Screen Replacement: adım 5, 2 resimden 1. HP Stream 7  Screen Replacement: adım 5, 2 resimden 2.
      • Remove the two 2 mm Phillips 000 screws from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. HP Stream 7  Screen Replacement: adım 6, 2 resimden 1. HP Stream 7  Screen Replacement: adım 6, 2 resimden 2.
      • Once unscrewed, the motherboard separates from the rest of the device.
      • The speaker is soldered to the motherboard, but it comes off easily.
      • Forced separation may result in a damaged motherboard and/or personal injury.
      FixBot'a Sor
      Yorum Ekle
    1. HP Stream 7  Screen Replacement, Screen Replacement: adım 7, 1 resimden 1.
      • After removing the motherboard, unscrew the four 2.5 mm Phillips 000 screws from the display panel.
      FixBot'a Sor
      Yorum Ekle
    2. HP Stream 7  Screen Replacement: adım 8, 1 resimden 1.
      • Using your spudger, pry the display panel off the front.
      FixBot'a Sor
      Yorum Ekle
    3. HP Stream 7  Screen Replacement: adım 9, 1 resimden 1.
      • The screen should now just come right off. Be sure to catch any broken bits if the screen is damaged.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Justin Schnorf
252 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-5, Forte Fall 2016 Cal Poly, Team 18-5, Forte Fall 2016 üyesi
CPSU-FORTE-F16S18G5
4 Üyeler
6 adet Kılavuz yazıldı
6Kılavuz Yorumları
where can i buy new screen????
eibrims - Yanıt Paylaş
Yeah, I want to know where I can buy a screen for my hp stream 7.
Rider Sd - Yanıt Paylaş
Where can i buy a new screen for the stream 7 please??
migueajr - Yanıt Paylaş
Same question but no answer !
Where can anyone find replacement screen online ??
Ahmed Saleh - Yanıt Paylaş
We're I can buy the replacement screen?
Raymond Borrero - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 27
Her zaman: 4,732
