Ana içeriğe geç
HP Stream 8 Motherboard Replacement
Neye ihtiyacın var
  1. HP Stream 8 Motherboard Replacement, Midframe: adım 1, 1 resimden 1.
    • Use your nail or a spudger to pry the back cover off of the device.
  2. HP Stream 8 Motherboard Replacement: adım 2, 1 resimden 1.
    • Slide your finger around the rest of the back cover, lifting it completely off of the device.
  3. HP Stream 8 Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove ten Phillips #00 screws from the inside cover.
  4. HP Stream 8 Motherboard Replacement: adım 4, 1 resimden 1.
    • Pry up the inside cover the same way as in the first step.
  5. HP Stream 8 Motherboard Replacement, Front-Facing Camera: adım 5, 1 resimden 1.
    • Lift up on the small black tab at the connection point to unlock the flex ribbon cable using the tweezers.
  6. HP Stream 8 Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove the front facing camera with tweezers.
  7. HP Stream 8 Motherboard Replacement, Rear-Facing Camera: adım 7, 1 resimden 1.
    • Carefully pry up the gray metal piece on the end of the flex ribbon cable using tweezers.
  8. HP Stream 8 Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove the back facing camera with the tweezers.
  9. HP Stream 8 Motherboard Replacement, Motherboard: adım 9, 1 resimden 1.
    • Carefully remove the battery connector from the system board using the tweezers.
  10. HP Stream 8 Motherboard Replacement: adım 10, 1 resimden 1.
    • Lift up on the small black tab to unlock the LCD screen flex ribbon cable using the tweezers.
  11. HP Stream 8 Motherboard Replacement: adım 11, 1 resimden 1.
    • Carefully remove the LCD screen flex ribbon cable from the system board using the tweezers.
  12. HP Stream 8 Motherboard Replacement: adım 12, 1 resimden 1.
    • Carefully remove the USB flex ribbon cable from the connection point on the system board using the tweezers.
  13. HP Stream 8 Motherboard Replacement: adım 13, 1 resimden 1.
    • Remove the two Phillips using the screwdriver with a PH00 Phillips head.
  14. HP Stream 8 Motherboard Replacement: adım 14, 1 resimden 1.
    • Remove the motherboard from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nick Miller
669 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 34-14, Maness Spring 2016 Cal Poly, Team 34-14, Maness Spring 2016 üyesi
CPSU-MANESS-S16S34G14
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 1,067
