Ana içeriğe geç
HP Stream x360 11-p010nr Battery Replacement
Neye ihtiyacın var
  1. HP Stream x360 11-p010nr Battery Replacement, Battery: adım 1, 3 resimden 1. HP Stream x360 11-p010nr Battery Replacement, Battery: adım 1, 3 resimden 2. HP Stream x360 11-p010nr Battery Replacement, Battery: adım 1, 3 resimden 3.
    • First, make sure the laptop is completely powered off and not charging to avoid electric shock.
    • Flip the laptop upside down then remove the seven 6.5 mm screws using a JIS J0 screwdriver.
    • Also remove the two 8.5 mm JIS J0 screws near the hinge of the laptop.
    • Peel back the two rubber feet near the hinge of the laptop to reveal and remove two more 8.5 mm JIS J0 screws.
    • The rubber feet near the speakers have no screws.
  2. HP Stream x360 11-p010nr Battery Replacement: adım 2, 2 resimden 1. HP Stream x360 11-p010nr Battery Replacement: adım 2, 2 resimden 2.
    • After removing all the screws, slowly and carefully lift the back cover, exposing the internal components.
    • Be careful not to damage the blue strip when opening the back case.
  3. HP Stream x360 11-p010nr Battery Replacement: adım 3, 3 resimden 1. HP Stream x360 11-p010nr Battery Replacement: adım 3, 3 resimden 2. HP Stream x360 11-p010nr Battery Replacement: adım 3, 3 resimden 3.
    • Carefully detach the blue strip that connects the back cover to the internals.
    • Make sure the blue tab is facing upwards when reassembling.
  4. HP Stream x360 11-p010nr Battery Replacement: adım 4, 3 resimden 1. HP Stream x360 11-p010nr Battery Replacement: adım 4, 3 resimden 2. HP Stream x360 11-p010nr Battery Replacement: adım 4, 3 resimden 3.
    • Using the JIS J0 screwdriver, unscrew the 6.5 mm screws surrounding the battery.
  5. HP Stream x360 11-p010nr Battery Replacement: adım 5, 1 resimden 1.
    • Carefully remove the surrounding wire away from the battery
  6. HP Stream x360 11-p010nr Battery Replacement: adım 6, 3 resimden 1. HP Stream x360 11-p010nr Battery Replacement: adım 6, 3 resimden 2. HP Stream x360 11-p010nr Battery Replacement: adım 6, 3 resimden 3.
    • Lastly, unhook the clip connecting the battery to the motherboard by pushing it away from the slot.
    • At this point, everything should be disconnected, simply remove the battery. Be sure to maneuver around the wire that runs between the middle of the battery.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Abdulaziz Alkulaib
116 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S7-G4, Cagle Spring 2017 USF Tampa, Team S7-G4, Cagle Spring 2017 üyesi
USFT-CAGLE-S17S7G4
4 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 3,799
