Ana içeriğe geç
HP Stream x360 11-p015wm Battery Replacement
Neye ihtiyacın var
  1. HP Stream x360 11-p015wm Battery Replacement, Back Cover: adım 1, 2 resimden 1. HP Stream x360 11-p015wm Battery Replacement, Back Cover: adım 1, 2 resimden 2.
    • Orient the laptop to have the back cover facing upwards.
    • Remove the four rubber pads located in each corner.
  2. HP Stream x360 11-p015wm Battery Replacement: adım 2, 1 resimden 1.
    • Tool required: JIS #1 Screwdriver
    • Using the screwdriver, remove all of the exposed screws.
  3. HP Stream x360 11-p015wm Battery Replacement: adım 3, 2 resimden 1. HP Stream x360 11-p015wm Battery Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    iFixit Opening Tool
    $1.99
    • Tool required: iFixit opening tool
    • Open the laptop and orient the keyboard facing upward.
    • Slowly wedge the opening tool into the gap between the keyboard and the back cover.
    • After loosening the back cover, close the laptop and orient the back cover facing upward. Open the cover.
  4. HP Stream x360 11-p015wm Battery Replacement: adım 4, 2 resimden 1. HP Stream x360 11-p015wm Battery Replacement: adım 4, 2 resimden 2.
    $3.99
    • This is a good time to clean any accumulated dust or debris. Use this link on tips for cleaning.
    • Tool required: Tweezers
    • Carefully use tweezers to remove the audio jack connector from the motherboard.
  5. HP Stream x360 11-p015wm Battery Replacement, Battery: adım 5, 3 resimden 1. HP Stream x360 11-p015wm Battery Replacement, Battery: adım 5, 3 resimden 2. HP Stream x360 11-p015wm Battery Replacement, Battery: adım 5, 3 resimden 3.
    • Use the JIS J1 screwdriver to remove the 6.5 mm screws surrounding the battery.
  6. HP Stream x360 11-p015wm Battery Replacement: adım 6, 3 resimden 1. HP Stream x360 11-p015wm Battery Replacement: adım 6, 3 resimden 2. HP Stream x360 11-p015wm Battery Replacement: adım 6, 3 resimden 3.
    • Using the iFixit tweezers, remove the cable connecting the battery to the motherboard.
    • Remove the wire located on the top side of the battery.
    • All connections should be removed. Simply remove the battery from the computer.
Sonuç
DaisyHaskell
701 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G2, Valliere Fall 2018 UMass Dartmouth, Team S1-G2, Valliere Fall 2018 üyesi
UMASSD-VALLIERE-F18S1G2
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 589
