Ana içeriğe geç
HP Stream x360 11-p015wm Motherboard Replacement
Neye ihtiyacın var
  1. HP Stream x360 11-p015wm Motherboard Replacement, Back Cover: adım 1, 2 resimden 1. HP Stream x360 11-p015wm Motherboard Replacement, Back Cover: adım 1, 2 resimden 2.
    • Orient the laptop to have the back cover facing upwards.
    • Remove the four rubber pads located in each corner.
  2. HP Stream x360 11-p015wm Motherboard Replacement: adım 2, 1 resimden 1.
    • Tool required: JIS #1 Screwdriver
    • Using the screwdriver, remove all of the exposed screws.
  3. HP Stream x360 11-p015wm Motherboard Replacement: adım 3, 2 resimden 1. HP Stream x360 11-p015wm Motherboard Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    iFixit Opening Tool
    $1.99
    • Tool required: iFixit opening tool
    • Open the laptop and orient the keyboard facing upward.
    • Slowly wedge the opening tool into the gap between the keyboard and the back cover.
    • After loosening the back cover, close the laptop and orient the back cover facing upward. Open the cover.
  4. HP Stream x360 11-p015wm Motherboard Replacement: adım 4, 2 resimden 1. HP Stream x360 11-p015wm Motherboard Replacement: adım 4, 2 resimden 2.
    $3.99
    • This is a good time to clean any accumulated dust or debris. Use this link on tips for cleaning.
    • Tool required: Tweezers
    • Carefully use tweezers to remove the audio jack connector from the motherboard.
  5. HP Stream x360 11-p015wm Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
    • Remove the six 6.5 mm Phillips head screws from the battery using the JIS #00 screwdriver.
  6. HP Stream x360 11-p015wm Motherboard Replacement: adım 6, 3 resimden 1. HP Stream x360 11-p015wm Motherboard Replacement: adım 6, 3 resimden 2. HP Stream x360 11-p015wm Motherboard Replacement: adım 6, 3 resimden 3.
    • Unplug the wire attaching to the battery to the motherboard using the tweezers.
    • Remove the battery.
  7. HP Stream x360 11-p015wm Motherboard Replacement: adım 7, 2 resimden 1. HP Stream x360 11-p015wm Motherboard Replacement: adım 7, 2 resimden 2.
    • Remove the six 3.5 mm screws from the silver plate cover with screwdriver JIS #00.
    • Remove the silver plate cover.
  8. HP Stream x360 11-p015wm Motherboard Replacement: adım 8, 2 resimden 1. HP Stream x360 11-p015wm Motherboard Replacement: adım 8, 2 resimden 2.
    • Remove the four 3.5 mm screws from the metal arm using the JIS #00 screwdriver.
  9. HP Stream x360 11-p015wm Motherboard Replacement: adım 9, 3 resimden 1. HP Stream x360 11-p015wm Motherboard Replacement: adım 9, 3 resimden 2. HP Stream x360 11-p015wm Motherboard Replacement: adım 9, 3 resimden 3.
    • Detach all remaining wires from the motherboard using the tweezers.
  10. HP Stream x360 11-p015wm Motherboard Replacement: adım 10, 2 resimden 1. HP Stream x360 11-p015wm Motherboard Replacement: adım 10, 2 resimden 2.
  11. HP Stream x360 11-p015wm Motherboard Replacement: adım 11, 2 resimden 1. HP Stream x360 11-p015wm Motherboard Replacement: adım 11, 2 resimden 2.
    • Remove the six 3.5 mm screws from the motherboard using the JIS #00 screwdriver.
    • Remove the motherboard.
Sonuç
Meredith Buganski
151 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S2-G3, Stella Fall 2019 IUPUI, Team S2-G3, Stella Fall 2019 üyesi
IUPUI-STELLA-F19S2G3
3 Üyeler
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 754
