Giriş
Use this guide to replace the power button, volume buttons, and ambient light sensor.
Neye ihtiyacın var
In the following steps, you will use a metal spudger to lift the front panel out from the rear case of your TouchPad.
As in the previous step, use a spudger to pry the front panel up from the rear case along its long edge on the volume button side of the TouchPad.
Continue to pry the front panel assembly up along the volume button side of the TouchPad until there is a gap between it and the rear case.
Use the edge of a plastic opening tool to flip up the retaining flap on the control button cable ZIF socket.
Pull the control button ribbon cable straight out of its socket on the motherboard.
3 farklı kişi bu kılavuzu tamamladı.
