Ana içeriğe geç
HP TouchPad Display Data Cable Replacement
Neye ihtiyacın var
    1. HP TouchPad Display Data Cable Replacement, Front Panel Assembly: adım 1, 1 resimden 1.
      • In the following steps, you will use a metal spudger to lift the front panel out from the rear case of your TouchPad.
      • The front panel is held in by seven clips (boxed in red) that are lightly anchored to the rear case. When you remove the front panel assembly, you are bound to break either the clips or their supports attached to the rear case. We will update this guide as we find replacement parts or a better method to remove the panel.
      • As you remove the front panel assembly, also be careful not to damage the ambient light sensor (boxed in yellow) or the two antennas (boxed in orange).
      FixBot'a Sor
      Yorum Ekle
    2. HP TouchPad Display Data Cable Replacement: adım 2, 1 resimden 1.
      • Insert a flat metal spudger in the gap between the rubber outer ring on the front panel assembly and the black plastic rear case near the USB connector.
      • Pry the front panel assembly up from the rear case, being careful not to damage the LCD or the glass panel.
      • As you work through the following steps, insert your metal spudger and pry the front panel up, but do not try to slide the spudger along the gap you're creating. Always remove your spudger, then insert it at another spot and pry upward.
      FixBot'a Sor
      Yorum Ekle
    3. HP TouchPad Display Data Cable Replacement: adım 3, 2 resimden 1. HP TouchPad Display Data Cable Replacement: adım 3, 2 resimden 2.
      • As in the previous step, use a spudger to pry the front panel up from the rear case along its long edge on the volume button side of the TouchPad.
      • Continue to pry the front panel assembly up along the volume button side of the TouchPad until there is a gap between it and the rear case.
      FixBot'a Sor
      Yorum Ekle
    4. HP TouchPad Display Data Cable Replacement: adım 4, 2 resimden 1. HP TouchPad Display Data Cable Replacement: adım 4, 2 resimden 2.
      • Pry up the front panel assembly along the top edge of the TouchPad.
      • Be careful not to damage the ambient light sensor or the upper antenna.
      FixBot'a Sor
      Yorum Ekle
    5. HP TouchPad Display Data Cable Replacement: adım 5, 1 resimden 1.
      • Pry up the front panel along the edge closest to the home screen button.
      FixBot'a Sor
      Yorum Ekle
    6. HP TouchPad Display Data Cable Replacement: adım 6, 2 resimden 1. HP TouchPad Display Data Cable Replacement: adım 6, 2 resimden 2.
      • Before lifting the free side of the front panel up from the rear case, you may need to release it from the plastic retaining clips holding it down.
      • Use your metal spudger to pull the stuck retaining clips away from the edge of the front panel.
      FixBot'a Sor
      Yorum Ekle
    7. HP TouchPad Display Data Cable Replacement: adım 7, 1 resimden 1.
      • After freeing the retaining clips, lift the front panel assembly away from the rear case.
      • Do not try to remove the front panel assembly from the TouchPad just yet, as it is still connected to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    8. HP TouchPad Display Data Cable Replacement: adım 8, 1 resimden 1.
      • Use the attached black tab to pull the display data cable straight up and out of its socket on the motherboard.
      • Pull the cable upwards and not parallel to the face of the motherboard. Doing otherwise may damage the socket on the motherboard.
      • Take care not to pull on the ribbon that is stuck by adhesive to the bottom of cable you are detaching. It does not need to be disconnected.
      FixBot'a Sor
      Yorum Ekle
    9. HP TouchPad Display Data Cable Replacement: adım 9, 3 resimden 1. HP TouchPad Display Data Cable Replacement: adım 9, 3 resimden 2. HP TouchPad Display Data Cable Replacement: adım 9, 3 resimden 3.
      • Use your fingernail to carefully flip up the retaining flaps on the two digitizer ribbon cable ZIF sockets.
      • Be sure you are prying up on the hinged retaining flaps, not the sockets themselves.
      • Pull the digitizer ribbon cable straight out of its two sockets on the motherboard.
      FixBot'a Sor
      Yorum Ekle
    10. HP TouchPad Display Data Cable Replacement: adım 10, 1 resimden 1.
      • Remove the front panel assembly from the rear case assembly.
      FixBot'a Sor
      Yorum Ekle
    1. HP TouchPad Display Data Cable Replacement, Display Data Cable: adım 11, 1 resimden 1.
      • Use the edge of a plastic opening tool to peel up the self-adhesive pull tab stuck to the display data cable.
      FixBot'a Sor
      Yorum Ekle
    2. HP TouchPad Display Data Cable Replacement: adım 12, 2 resimden 1. HP TouchPad Display Data Cable Replacement: adım 12, 2 resimden 2.
      • Pull the tab up and toward the middle of the display to unlock the display data cable connector from its socket on the LCD.
      • Pull the display data cable out of its socket on the LCD and set it aside.
      • Do not lift upward on the connector as you pull it out of its socket. Pull the connector parallel to the face of the LCD.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
3Kılavuz Yorumları
Hi! Don't suppose you know where I can get a replacement? Thanks!
Connor Roberts - Yanıt Paylaş
Can an old touchpad be repaired
Pat - Yanıt Paylaş
I have an older hp touchpad that is cracked. Can the screen be replaced
Pat - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 30
Her zaman: 7,658
