Giriş
Use this guide to replace a broken headphone jack.
Neye ihtiyacın var
In the following steps, you will use a metal spudger to lift the front panel out from the rear case of your TouchPad.
As in the previous step, use a spudger to pry the front panel up from the rear case along its long edge on the volume button side of the TouchPad.
Continue to pry the front panel assembly up along the volume button side of the TouchPad until there is a gap between it and the rear case.
Use the edge of a plastic opening tool to flip up the retaining flap on the headphone jack ribbon cable ZIF socket.
Pull the headphone jack ribbon cable out of its socket.
2 farklı kişi bu kılavuzu tamamladı.
