Ana içeriğe geç
HP TouchSmart 15-r015dx Screen Replacement
Neye ihtiyacın var
  1. HP TouchSmart 15-r015dx Screen Replacement, Screen: adım 1, 3 resimden 1. HP TouchSmart 15-r015dx Screen Replacement, Screen: adım 1, 3 resimden 2. HP TouchSmart 15-r015dx Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Acquire the metal spudger and a Precision Magnetized Driver with J1 size bit.
    • Flip your HP TouchSmart 15 over.
  2. HP TouchSmart 15-r015dx Screen Replacement: adım 2, 3 resimden 1. HP TouchSmart 15-r015dx Screen Replacement: adım 2, 3 resimden 2. HP TouchSmart 15-r015dx Screen Replacement: adım 2, 3 resimden 3.
    • Locate tabs on the underside of the laptop.
    • Push both tabs towards the center of the laptop and pull away to remove battery.
  3. HP TouchSmart 15-r015dx Screen Replacement: adım 3, 3 resimden 1. HP TouchSmart 15-r015dx Screen Replacement: adım 3, 3 resimden 2. HP TouchSmart 15-r015dx Screen Replacement: adım 3, 3 resimden 3.
    • Take the sharp end of the pry tool and pop out the black screw cover.
    • Repeat on opposite side.
  4. HP TouchSmart 15-r015dx Screen Replacement: adım 4, 3 resimden 1. HP TouchSmart 15-r015dx Screen Replacement: adım 4, 3 resimden 2. HP TouchSmart 15-r015dx Screen Replacement: adım 4, 3 resimden 3.
    • Take the Precision Magnetized Driver with J1 size bit and unscrew the screw.
  5. HP TouchSmart 15-r015dx Screen Replacement: adım 5, 3 resimden 1. HP TouchSmart 15-r015dx Screen Replacement: adım 5, 3 resimden 2. HP TouchSmart 15-r015dx Screen Replacement: adım 5, 3 resimden 3.
    • Using the pry tool, begin to separate the touchscreen from the plastic backing.
  6. HP TouchSmart 15-r015dx Screen Replacement: adım 6, 3 resimden 1. HP TouchSmart 15-r015dx Screen Replacement: adım 6, 3 resimden 2. HP TouchSmart 15-r015dx Screen Replacement: adım 6, 3 resimden 3.
    • Close the laptop and flip it over once again.
    • Continue to pry the touchscreen from the plastic backing in the hinged area of the laptop.
  7. HP TouchSmart 15-r015dx Screen Replacement: adım 7, 3 resimden 1. HP TouchSmart 15-r015dx Screen Replacement: adım 7, 3 resimden 2. HP TouchSmart 15-r015dx Screen Replacement: adım 7, 3 resimden 3.
    • Flip over the laptop and open it.
    • Pull up on the separated touchscreen while pulling it away from the plastic backing.
    • Be careful while laying down the touchscreen to not pull the connection point.
    • Lay the touchscreen on the keyboard facedown.
  8. HP TouchSmart 15-r015dx Screen Replacement: adım 8, 3 resimden 1. HP TouchSmart 15-r015dx Screen Replacement: adım 8, 3 resimden 2. HP TouchSmart 15-r015dx Screen Replacement: adım 8, 3 resimden 3.
    • Locate the connection point.
    • Slowly and carefully peel off.
  9. HP TouchSmart 15-r015dx Screen Replacement: adım 9, 2 resimden 1. HP TouchSmart 15-r015dx Screen Replacement: adım 9, 2 resimden 2.
    • Isolate the touchscreen from the keyboard.
  10. HP TouchSmart 15-r015dx Screen Replacement: adım 10, 3 resimden 1. HP TouchSmart 15-r015dx Screen Replacement: adım 10, 3 resimden 2. HP TouchSmart 15-r015dx Screen Replacement: adım 10, 3 resimden 3.
    • Begin by peeling off the black adhesive tape using the pry tool.
    • Once adhesive tape is removed, use the pry tool to remove the tab in the corner. Repeat in each corner.
  11. HP TouchSmart 15-r015dx Screen Replacement: adım 11, 3 resimden 1. HP TouchSmart 15-r015dx Screen Replacement: adım 11, 3 resimden 2. HP TouchSmart 15-r015dx Screen Replacement: adım 11, 3 resimden 3.
    • Using the sharp end of the pry tool, separate the plastic from the screen.
  12. HP TouchSmart 15-r015dx Screen Replacement: adım 12, 1 resimden 1.
    • Now it is time to reassemble your device with a new screen.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Amazing work. I would not change a thing.
Dan Hartzell - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 19
Her zaman: 1,203
