Ana içeriğe geç
HP Touchsmart IQ506 RAM (Memory) Replacement
Neye ihtiyacın var
    1. HP Touchsmart IQ506 RAM (Memory) Replacement, Change note: adım 1, 2 resimden 1. HP Touchsmart IQ506 RAM (Memory) Replacement, Change note: adım 1, 2 resimden 2.
      Bu adımda kullanılan alet:
      Essential Electronics Toolkit
      $29.95
      • Due to the EET missing several components present in the Pro Tech Go and only being $20 cheaper, the EET has been removed. The EET will work for this guide as-is, but if you are shopping for a new toolkit to complete this guide, the Pro Tech Go (new or refurbished, refurbished is ~$32 cheaper), or Pro Tech ($79 new/~$59.95 refurb) is the current recommended toolkit for this guide.
      • If you are interested in a refurbished kit stock levels change frequently but can be found here.
      FixBot'a Sor
      Yorum Ekle
    1. HP Touchsmart IQ506 RAM (Memory) Replacement, Unplug the system: adım 2, 2 resimden 1. HP Touchsmart IQ506 RAM (Memory) Replacement, Unplug the system: adım 2, 2 resimden 2.
      • Unplug the power brick from the system.
      FixBot'a Sor
      Yorum Ekle
    2. HP Touchsmart IQ506 RAM (Memory) Replacement, Remove the RAM door: adım 3, 3 resimden 1. HP Touchsmart IQ506 RAM (Memory) Replacement, Remove the RAM door: adım 3, 3 resimden 2. HP Touchsmart IQ506 RAM (Memory) Replacement, Remove the RAM door: adım 3, 3 resimden 3.
      • Unscrew the RAM door using a Phillips #1 screwdriver. Snap the RAM door off from the bottom and slide it off.
      FixBot'a Sor
      Yorum Ekle
    3. HP Touchsmart IQ506 RAM (Memory) Replacement, Remove the RAM: adım 4, 2 resimden 1. HP Touchsmart IQ506 RAM (Memory) Replacement, Remove the RAM: adım 4, 2 resimden 2.
      • With the RAM exposed, remove the RAM from the slots on the system by pushing the tabs back. Once you do this the RAM will pop up and you can remove it.
      • Install the new RAM. Make sure you line the tab up on the memory with the slot in the system. It should only go in one way.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Nick
105.479 İtibar
72 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 36
Her zaman: 1,198
