Ana içeriğe geç
HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement
Neye ihtiyacın var
  1. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Batteries: adım 1, 3 resimden 1. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Batteries: adım 1, 3 resimden 2. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Batteries: adım 1, 3 resimden 3.
    • Slide the rear compartment cover in the direction of the arrow.
    • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
  2. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Shell: adım 2, 2 resimden 1. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Shell: adım 2, 2 resimden 2.
    • Remove the four 4mm screws using a Phillips #00 screwdriver.
  3. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: adım 3, 3 resimden 1. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: adım 3, 3 resimden 2. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: adım 3, 3 resimden 3.
    • Grip the main body and pull the joystick outwards until the entire front panel pops off.
    • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
  4. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: adım 4, 2 resimden 1. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: adım 4, 2 resimden 2.
    • Use a spudger to pry apart the two halves of the assembly.
    • Work slowly, prying a small section at a time until the halves are completely separated.
  5. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Small Circuit Board: adım 5, 2 resimden 1. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Small Circuit Board: adım 5, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove the four 4mm screws located on the joystick circuit board underneath the top half of the controller.
  6. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: adım 6, 3 resimden 1. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: adım 6, 3 resimden 2. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: adım 6, 3 resimden 3.
    • Remove the orange flat cable by pulling the orange tab parallel to the circuit board.
    • Release the blue flat cable by lifting up the white latch with a spudger.
  7. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Main Circuit Board: adım 7, 3 resimden 1. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Main Circuit Board: adım 7, 3 resimden 2. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Main Circuit Board: adım 7, 3 resimden 3.
    • Remove the two 6mm screws at the base of the ring using a Phillips #0 screwdriver.
    • Pull towards the base of the controller to release the black wire from the connector on the circuit board.
    • Pull the ring apart from the rest of the controller.
  8. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: adım 8, 3 resimden 1. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: adım 8, 3 resimden 2. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: adım 8, 3 resimden 3.
    • Remove the two 3mm screws on the V-clip using a Phillips #00 screwdriver.
    • Remove the V-clip from the device.
  9. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: adım 9, 3 resimden 1. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: adım 9, 3 resimden 2. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: adım 9, 3 resimden 3.
    • With the V-clip off of the controller, use a Phillips #00 screwdriver to remove the remaining 4mm screw.
    • Remove the circuit board.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Eeshan Mishra
424 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G2, Maness Spring 2019 Cal Poly, Team S1-G2, Maness Spring 2019 üyesi
CPSU-MANESS-S19S1G2
4 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
Awesome! But were do you get the components to replace from??
Since separate controllers are very difficult to find and expensive (You wont find Samsung ones) I will be interested to buy a few to do repairs to friends and so.
Baba Nam Kevalam - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 1,882
