Ana içeriğe geç
HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement
Neye ihtiyacın var
  1. HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement, Batteries: adım 1, 3 resimden 1. HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement, Batteries: adım 1, 3 resimden 2. HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement, Batteries: adım 1, 3 resimden 3.
    • Slide the rear compartment cover in the direction of the arrow.
    • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
    FixBot'a Sor
    Yorum Ekle
  2. HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement, Shell: adım 2, 2 resimden 1. HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement, Shell: adım 2, 2 resimden 2.
    • Remove the four 4mm screws using a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement: adım 3, 3 resimden 1. HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement: adım 3, 3 resimden 2. HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement: adım 3, 3 resimden 3.
    • Grip the main body and pull the joystick outwards until the entire front panel pops off.
    • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement: adım 4, 2 resimden 1. HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement: adım 4, 2 resimden 2.
    • Use a spudger to pry apart the two halves of the assembly.
    • Work slowly, prying a small section at a time until the halves are completely separated.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Clement Cheung
643 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G5, White Winter 2019 Cal Poly, Team S18-G5, White Winter 2019 üyesi
CPSU-WHITE-W19S18G5
2 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 21
Her zaman: 1,192
