Ana içeriğe geç
HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement
Neye ihtiyacın var
  1. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: adım 1, 3 resimden 1. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: adım 1, 3 resimden 2. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: adım 1, 3 resimden 3.
    • Slide the rear compartment cover in the direction of the arrow.
    • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
    FixBot'a Sor
    Yorum Ekle
  2. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Shell: adım 2, 2 resimden 1. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Shell: adım 2, 2 resimden 2.
    • Remove the four 4mm screws using a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: adım 3, 3 resimden 1. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: adım 3, 3 resimden 2. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: adım 3, 3 resimden 3.
    • Grip the main body and pull the joystick outwards until the entire front panel pops off.
    • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: adım 4, 2 resimden 1. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: adım 4, 2 resimden 2.
    • Use a spudger to pry apart the two halves of the assembly.
    • Work slowly, prying a small section at a time until the halves are completely separated.
    FixBot'a Sor
    Yorum Ekle
  5. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: adım 5, 3 resimden 1. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: adım 5, 3 resimden 2. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: adım 5, 3 resimden 3.
    • Grasp the trigger with one hand while pushing against the outer wall of the shell.
    • Apply pressure, pulling the wall away from the trigger.
    • Remove the trigger starting from the freed edge.
    • The spring-rod assembly can easily come apart. Inserting the large end first during reassembly may make the process easier.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Clement Cheung
643 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G5, White Winter 2019 Cal Poly, Team S18-G5, White Winter 2019 üyesi
CPSU-WHITE-W19S18G5
2 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 30
Her zaman: 1,964
