Ana içeriğe geç
HP Windows Mixed Reality VR1000-100 Headband Replacement
Neye ihtiyacın var
  1. HP Windows Mixed Reality VR1000-100 Headband Replacement, Headband: adım 1, 1 resimden 1.
    • Peel off the adhesive foam on the front side of the headband.
    • When reassembling, you may have to manually reapply adhesive to get the foam back on.
  2. HP Windows Mixed Reality VR1000-100 Headband Replacement: adım 2, 2 resimden 1. HP Windows Mixed Reality VR1000-100 Headband Replacement: adım 2, 2 resimden 2.
    • Remove the three screws holding the internal headband plate to the headband using a Phillips #00 screwdriver.
    • Pry off the internal headband plate using an opening tool.
  3. HP Windows Mixed Reality VR1000-100 Headband Replacement: adım 3, 2 resimden 1. HP Windows Mixed Reality VR1000-100 Headband Replacement: adım 3, 2 resimden 2.
    • Remove four screws that hold the headband to the headset (two on each side) using a Phillips #00 screwdriver.
    • Using your hands, pull out the headband from the headset.
Sonuç
Christopher Green
231 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-4, Ramos Fall 2023 UMass Dartmouth, Team 5-4, Ramos Fall 2023 üyesi
UMASSD-RAMOS-F23S5G4
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 74
