Ana içeriğe geç
HP Windows Mixed Reality VR1000-100 Internal Headphone Input Replacement
Neye ihtiyacın var
  1. HP Windows Mixed Reality VR1000-100 Internal Headphone Input Replacement, Internal Headphone Input: adım 1, 3 resimden 1. HP Windows Mixed Reality VR1000-100 Internal Headphone Input Replacement, Internal Headphone Input: adım 1, 3 resimden 2. HP Windows Mixed Reality VR1000-100 Internal Headphone Input Replacement, Internal Headphone Input: adım 1, 3 resimden 3.
    • Pry off the plastic plate on the front of the headset.
    • Remove 14 screws from the front part of the headset using a Phillips #0 screwdriver.
    • Separate the back side of the headset from the front side.
  2. HP Windows Mixed Reality VR1000-100 Internal Headphone Input Replacement: adım 2, 2 resimden 1. HP Windows Mixed Reality VR1000-100 Internal Headphone Input Replacement: adım 2, 2 resimden 2.
    • Remove two screws from the 3.5mm audio input using a Phillips #0 screwdriver.
    • Carefully remove the wire from the audio input.
    • The audio jack should fall out once both the wire and the screws have been removed.
Sonuç
Christopher Green
231 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-4, Ramos Fall 2023 UMass Dartmouth, Team 5-4, Ramos Fall 2023 üyesi
UMASSD-RAMOS-F23S5G4
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 24
Her zaman: 110
