Ana içeriğe geç
HP Z2 Mini G3 Access Panel Replacement
  1. HP Z2 Mini G3 Access Panel Replacement, Access Panel: adım 1, 1 resimden 1.
    • Turn the device so the back-side of the device is facing you.
    • Be sure that the power is off and the A/C power cord has been disconnected before starting. Removing hardware while the power is on could damage the device or harm yourself.
    • Components of the device are subject to static damage. Work on a hard, grounded surface to prevent damage to the workstation.
  2. HP Z2 Mini G3 Access Panel Replacement: adım 2, 2 resimden 1. HP Z2 Mini G3 Access Panel Replacement: adım 2, 2 resimden 2.
    • Slide and hold the latch in the direction of the engraved arrow (to the right).
  3. HP Z2 Mini G3 Access Panel Replacement: adım 3, 2 resimden 1. HP Z2 Mini G3 Access Panel Replacement: adım 3, 2 resimden 2.
    • While holding the latch, lift the access panel upwards and towards yourself and set it aside upside-down.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 33
Her zaman: 977
