Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Turn the device so the back-side of the device is facing you.
Slide and hold the latch in the direction of the engraved arrow (to the right).
While holding the latch, lift the access panel upwards and towards yourself and set it aside upside-down.
Rotate the device so the front side is facing you (the side with the power button) and locate the CPU fan.
Carefully disconnect the CPU fan by pulling out the wires from the motherboard.
Swing the fan back down and carefully unhook the CPU fan notches by pulling each tab away from the heat sink holes.
Bir başkası bu kılavuzu tamamladı.
