Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Turn the device so the back-side of the device is facing you.
Slide and hold the latch in the direction of the engraved arrow (to the right).
While holding the latch, lift the access panel upwards and towards yourself and set it aside upside-down.
Rotate the device so the front side is facing you (the side with the power button) and locate the CPU fan.
Carefully disconnect the CPU fan by pulling out the wires from the motherboard.
Swing the fan back down and carefully unhook the CPU fan notches by pulling each tab away from the heat sink holes.
Remove the 9mm Torx screw with a T15 Torx screwdriver to release the SSD assembly.
Lift the assembly upwards to remove it.
Pull the metal arm out from under the frame and lift it up. The frame should slide back from under the screw.
Grip the processor on each side, carefully lifting it up.
