Ana içeriğe geç
HP ZBook 15 4G Network Module Replacement
Neye ihtiyacın var
  1. HP ZBook 15 4G Network Module Replacement, Battery: adım 1, 2 resimden 1. HP ZBook 15 4G Network Module Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
    FixBot'a Sor
    Yorum Ekle
  2. HP ZBook 15 4G Network Module Replacement, Back Cover: adım 2, 1 resimden 1.
    • Slide the right lever firmly to the right.
    • Slide the cover towards yourself to remove it.
    FixBot'a Sor
    Yorum Ekle
  3. HP ZBook 15 4G Network Module Replacement, 4G Network Module: adım 3, 1 resimden 1.
    • Remove the two connectors by lifting gently with a metal spudger.
    FixBot'a Sor
    Yorum Ekle
  4. HP ZBook 15 4G Network Module Replacement: adım 4, 2 resimden 1. HP ZBook 15 4G Network Module Replacement: adım 4, 2 resimden 2.
    • Remove the 3mm screw with a Phillips #0 screwdriver.
    • Remove the 4G Module by lifting up and out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Grant Terris
2.888 İtibar
12 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-43, Amido Winter 2015 Cal Poly, Team 8-43, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S8G43
4 Üyeler
19 adet Kılavuz yazıldı
1Rehber Yorum
this instructions were very useful
PRINCE - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 52
Her zaman: 5,778
