Ana içeriğe geç
HP ZBook 15 Optical Drive Replacement
Neye ihtiyacın var
  1. HP ZBook 15 Optical Drive Replacement, Battery: adım 1, 2 resimden 1. HP ZBook 15 Optical Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
  2. HP ZBook 15 Optical Drive Replacement, Back Cover: adım 2, 1 resimden 1.
    • Slide the right lever firmly to the right.
    • Slide the cover towards yourself to remove it.
  3. HP ZBook 15 Optical Drive Replacement, Optical Drive: adım 3, 1 resimden 1.
    • Unscrew the captive screw shown near the battery compartment with a Phillips #0 screwdriver.
    • The screw does not come out all the way and stays attached to the computer.
    Missed 3 screws to be removed before pushing the optical drive!
    Vincent Rouillard - Yanıt
    Actually there are 4 screws
  4. HP ZBook 15 Optical Drive Replacement: adım 4, 3 resimden 1. HP ZBook 15 Optical Drive Replacement: adım 4, 3 resimden 2. HP ZBook 15 Optical Drive Replacement: adım 4, 3 resimden 3.
    • Push outward on the metal optical drive tab with a metal spudger to unlock the drive from its position in the case.
    • Once the drive is protruding from the side of the computer, pull it the rest of the way out.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Grant Terris
2.828 İtibar
12 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-43, Amido Winter 2015 Cal Poly, Team 8-43, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S8G43
4 Üyeler
15 adet Kılavuz yazıldı
2 Yorum
Mine won't come out and now I think my silver tab is bent. Please help me!
Sajid - Yanıt
Oddly enough, mine came with no DVD drive but a blanking… thing, which seems to be a trimmed-down version of this official adapter (HP SPS 734298-001) without the electronics. I bought a cheap chinese ODD caddy, tore it down and salvaged the logic board. Luckily, I got everything lined up after a few adjustments (the chinese logic board is a bit longer than the HP one).
Now I’m rocking an extra drive bay without paying the $75 some shops ask for the official one.
I use it as swappable storage (not hot-swappable, mind you) . Very handy for doing drive imaging and cloning when working as an IT technician out in the field.
Luis Alejandro Araúz - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 14
Son 30 gün: 33
Her zaman: 6,733
