Ana içeriğe geç
HP Zbook 15u G2 RAM Replacement
Neye ihtiyacın var
    1. HP Zbook 15u G2 RAM Replacement, RAM/Memory: adım 1, 1 resimden 1.
      • Flip the laptop on its side and flip the switch at the top so the red side is visible. This will allow you to slide off the back panel as shown.
      FixBot'a Sor
      Yorum Ekle
    2. HP Zbook 15u G2 RAM Replacement: adım 2, 2 resimden 1. HP Zbook 15u G2 RAM Replacement: adım 2, 2 resimden 2.
      • Once the back panel is removed, flip the 2 switches located on the battery so the red is visible.
      • Lift the battery out of the device by pulling up on the tab located between the two switches at the top of the battery.
      FixBot'a Sor
      Yorum Ekle
    3. HP Zbook 15u G2 RAM Replacement: adım 3, 1 resimden 1.
      • Once you have removed the back panel, you must locate the RAM. The RAM comes in two pieces on the ZBook.
      • Located at the top of the computer, the ram can be located as a part of two pieces held together with a metal clip.
      FixBot'a Sor
      Yorum Ekle
    4. HP Zbook 15u G2 RAM Replacement: adım 4, 1 resimden 1.
      • Gently pull back the clips and remove the RAM module, which will pop out. Repeat this step for the second RAM Module.
      FixBot'a Sor
      Yorum Ekle
    5. HP Zbook 15u G2 RAM Replacement: adım 5, 1 resimden 1.
      • Slide the new RAM module back into place and push the module into place. Repeat this process for the second RAM Module.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nicole Kach
279 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-5, Petersen Spring 2023 UMass Dartmouth, Team 3-5, Petersen Spring 2023 üyesi
UMASSD-PETERSEN-S23S3G5
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 29
Her zaman: 440
